I'm working on the robot-car thing. The deal is I have an L298 test-program for the wheel-motors (motor A and motor B) that I lifted from somewhere (hat-tip to the author and apols for not crediting) that works fine
// connect motor controller pins to Arduino digital pins
// motor A
int enA = 10;
int in1 = 9;
int in2 = 8;
// motor B
int enB = 5;
int in3 = 6;
int in4 = 7;
// set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
demoOne();
delay(5000);
void demoOne()
// this function will run the motors in both directions at a fixed speed
// turn on motor A
digitalWrite(in1, HIGH); // This is the pattern for Motor A going forward
digitalWrite(in2, LOW); // This is the pattern for Motor A going forward
Serial.println("Motor A engaged");
// set speed to 200 out of possible range 0~255
analogWrite(enA, 200);
// turn on motor B
digitalWrite(in3, LOW); // This is the pattern for Motor B going forward
digitalWrite(in4, HIGH); // This is the pattern for Motor B going forward
Serial.println("Motor B engaged");
analogWrite(enB, 200);
Serial.println("Both motors in reverse");
delay(2000);
// now change motor directions
digitalWrite(in1, LOW); // This is the pattern for Motor A in reverse
digitalWrite(in2, HIGH); // This is the pattern for Motor A in reverse
digitalWrite(in3, HIGH); // This is the pattern for Motor B in reverse
digitalWrite(in4, LOW); // This is the pattern for Motor B in reverse
Serial.println("Both motors going forward");
delay(2000);
// now turn off motors
Serial.println("Both motors off");
However when I incorporate a tweak of this code into the robot-car program only motor B starts - I can swap the order the motors start, I can even remark-out the code for motor B - motor A just won't start.
After further fiddling about I've discovered that if I remark-out the servo-code (which moves the ultrasonic-head left and right to check for obstacles), motor A starts as does motor B.
I'm powering the wheelmotors from a stack of assorted batteries and I know from the L298 test-code that power from that lot isn't a problem. I'm powering the Arduino (and indirectly the servo motor) via the USB - once I've got the whole thing working I will power the Arduino separately from the wheel-motors.
The earlier thread suggested all those analogWrites() in close conjunction might be a problem, but they work fine in the L298 test-code so why not in the main car-code?
The servo motor is powered from pin 4 on the Arduino if that's in any way relevant. I have a separate servo-test program that works fine.
Help welcome!
The Servo library uses timer1 of the processor and so does analogWrite() on pins 9 and 10. Hence when using the Servo library analogWrite() cannot be used on those pins
