Hello,
I recently built a motor controlled lathe using the sabertooth 2x25 and the packetized serial method. I just got a request from someone who is using the lathe tomorrow to have the lathe traverse back and forth automatically. I built the lathe with an overtravel switch on each end of the bed, so all of the hardware is in place. Basically all I need the lathe to do is go the entire length in one direction until switch is activated and then reverse course in the other direction until switch is activated and repeat. Would anyone be able to get me jumpstarted on the correct path to facilitate this request.
Rod M.
//*********** DEADMAN SWITCH MUST BE PRESSED IN, MOTORS WILL STOP IF RELEASED **********************
//ONLY THING YOU NEED IS DEAD MAN SWITCH TO DIGITAL PIN 9 (Ground TO PIN 9 WHEN SWITCH PRESSED)
//J. Dingley March 1 2011 For Arduino 328 Duemalinove or similar with a 3.3V accessory power output
//i.e. the current standard Arduino board.
//Modified by R. Morgan 2/4/12
#include <SoftwareSerial.h>
//******************** IMPORTANT ***************************
//Set dip switches on the Sabertooth for simplified serial and 9600 Buadrate.
//i.e. DIP switches 1, 3, 5 and 6 set to ON, the remainder set to OFF
#define SABER_TX_PIN 13 //Digital pin 13 is serial transmit pin to sabertooth
#define SABER_RX_PIN 12 //Not used but still initialised, Digital pin 12 is serial receive from Sabertooth
#define SABER_BAUDRATE 9600 //set baudrate to match sabertooth dip settings
#define SABER_MOTOR1_FULL_FORWARD 127 //simplifierd serial limits for each motor
#define SABER_MOTOR1_FULL_REVERSE 1
#define SABER_MOTOR2_FULL_FORWARD 255
#define SABER_MOTOR2_FULL_REVERSE 128
#define SABER_ALL_STOP 0 //motor level to send when issuing full stop command
SoftwareSerial SaberSerial = SoftwareSerial (SABER_RX_PIN, SABER_TX_PIN ); //initialise software to communicate with sabertooth
void initSabertooth (void)
pinMode ( SABER_TX_PIN, OUTPUT );
SaberSerial.begin( SABER_BAUDRATE );
delay (2000); //2 sec delay to let it settle
SaberSerial.print(0, BYTE); //kill motors when first switched on
delay (1000);
float level = 0;
int k4;
int deadmanbuttonPin = 9; // deadman button is digital input pin 9
const int ledPin = 3;
int ledState = LOW;
long previousMillis = 0;
long interval = 250;
int rc_switch = 5;
int rc;
int sensorPin1 = A0; //sets up A0 as the potentiometer input
int sensorPin2 = A1; //sets up potentiometer on A1
int sensorValue_long = 0;
int sensorValue_lat = 0;
int right_traverse_limit = 12;
int right;
int left_traverse_limit = 11;
int left;
int a;
int b;
unsigned long transmitterchannel1=0;
unsigned long transmitterchannel2=0;
int ch1;
int ch2;
void setup() // run once, when the sketch starts
initSabertooth( ); //runs sabertooth initialization
pinMode(deadmanbuttonPin, INPUT); //set inputs
pinMode (ledPin, OUTPUT); //sets up pin 3 for indicator light
pinMode (rc_switch, INPUT); //sets up pin 5 for rc/hardwired selector
pinMode(right_traverse_limit, INPUT); //sets overtravel switch inputs
pinMode(left_traverse_limit, INPUT); //sets overtravel switch inputs
pinMode (transmitterchannel1, INPUT); //sets up pin for RC input
pinMode (transmitterchannel2, INPUT); //sets up pin for RC input
digitalWrite(deadmanbuttonPin, 1); //activates internal resistors
digitalWrite(right_traverse_limit, 1); //activates internal resistors
digitalWrite(left_traverse_limit, 1); //activates internal resistors
digitalWrite(rc_switch, 1); //activates internal resistors
Serial.begin(9600); // HARD wired Serial feedback to PC for debugging in Wiring
void checkTransmitter()
transmitterchannel1 = (pulseIn (7, HIGH, 100000))/10; //read RC channel, wait max of 0.1 seconds for pulse
transmitterchannel2 = (pulseIn (8, HIGH, 100000))/10; //read RC channel, wait max of 0.1 seconds for pulse
ch2 = map(transmitterchannel2, 106, 193, 1, 127); //converts value to number used by controller
ch1 = map(transmitterchannel1, 106, 193, 128, 255); //converts value to number used by controller
if (ch2 < 1 || ch2 > 127) ch2 = 0;
if (ch1 < 128 || ch1 > 255) ch1 = 0;
void transmitterread()
checkTransmitter();//check the data being received by the transmitter.
Serial.print ("ch1 data: ");
Serial.println (ch1);
Serial.print ("ch2 data:");
Serial.println (ch2);
void auto() //this will be the loop that automatically changes direction of the motor depending on the traverse switches
void set_motor()
unsigned char cSpeedVal_Motor1 = 0;
unsigned char cSpeedVal_Motor2 = 0; //set motors using the simplified serial Sabertooth protocol
Serial.println ("#########################");
cSpeedVal_Motor1 = sensorValue_long;
cSpeedVal_Motor2 = sensorValue_lat;
Serial.println("**********");
Serial.println(cSpeedVal_Motor1);
Serial.println(cSpeedVal_Motor2);
SaberSerial.print (cSpeedVal_Motor1, BYTE);
SaberSerial.print (cSpeedVal_Motor2, BYTE);
void set_motor_rc()
unsigned char ch1 = 0;
unsigned char ch2 = 0; //set motors using the simplified serial Sabertooth protocol
cSpeedVal_Motor1 = ch1;
cSpeedVal_Motor2 = ch2;
void loop ()
int val = 0;
for (int i=0; i< 16; i++) val += analogRead(sensorPin1); //averages values
sensorValue_long = val/16;
val = 0;
for (int i=0; i< 16; i++) val += analogRead(sensorPin2); //averages values
sensorValue_lat= val/16;
int v = sensorValue_long - 512 ; // expands center pot "dead" spot
if (v < -50) v += 50 ;
else if (v > 50) v -= 50 ;
else v = 0 ;
int w = sensorValue_lat - 512 ; // expands center pot "dead" spot
if (w < -50) w += 50 ;
else if (w > 50) w -= 50 ;
else w = 0 ;
sensorValue_long = map(v, -462, 461, 1, 127); //converts value to number used by controller
sensorValue_lat = map(w, -462, 461, 128, 255); //converts value to number used by controller
digitalWrite (3, LOW);
Serial.print("Long Data: ");
Serial.println(sensorValue_long);
Serial.print("Lat Data: ");
Serial.println(sensorValue_lat);
//delay (200);
k4 = digitalRead(deadmanbuttonPin);
right = digitalRead(right_traverse_limit);
left = digitalRead(left_traverse_limit);
if (rc > 1)auto();
while (k4 > 0)
Serial.println("Switch is OFF");
if(currentMillis - previousMillis > interval) { // save the last time you blinked the LED
previousMillis = currentMillis; // if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
digitalWrite(ledPin, ledState); // set the LED with the ledState of the variable:
while (right < 1) //reverses motor for 750 ms after right traverse limit switch is engaged
cSpeedVal_Motor1 = 50;
Serial.println("Right limit reached");
delay (750);
while (left < 1)
cSpeedVal_Motor1 = 84;
Serial.println("Left limit reached");
delay (750);
//if (rc > 1) {
// set_motor_analog();
// rc = digitalRead (rc_switch); //includes transmitterread() loop if switch is acitve --saves processing--
// if (rc < 1) {
// transmitterread();
//set_motor_rc();
//Serial.println ("rc is active");
ledState = HIGH;
ledState = LOW;
set_motor();
