would love some help getting mqtt payload showing on my display have try some example but cant get them to work as all of them interfere with currant subscribe i need more than just one thankyou to anyone that helps me with this mess currant code works just cant get raw payloads on screen
// Example: LCDML: graphic display with u8g
// Author: Jomelo
// Last update: 21.01.2018
// License: MIT
// Description:
// This example shows how to use the u8glib with the LCDMenuLib
// The menu can placed in a box that can be placed anywhere on
// the screen.
// special settings
// enable this line when you are not usigng a standard arduino
// for example when your chip is an ESP or a STM or SAM or something else
#define _LCDML_cfg_use_ram
// include libs
#include <LCDMenuLib2.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <ArduinoOTA.h>
#include <stdlib.h>
// U8g2lib
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
// WiFi
const char *ssid = "whataday"; // Enter your WiFi name
const char *password = "djfkddk"; // Enter WiFi password
// MQTT Broker
const char *mqtt_broker = "192.168.0.26";
const char *pump = "cmnd/75gpumps/power";
const char *power_head = "cmnd/75gpumps/power2";
const char *protein_skimmer = "cmnd/75gpumps/power3";
const char *uv = "cmnd/75gpumps/power4";
const char *ligths = "cmnd/75glights/power1";
const char *ato = "cmnd/75gdosingpumps/power5";
const char *feed = "cmnd/hass/feedmode";
const char *hass = "cmnd/hass/hass";
const char *temp = "cmnd/tank1/temp";
const char *atom = "cmnd/tank1/atom";
const char *atofill = "cmnd/hass/atof";
const char *mqtt_username = "djfkd";
const char *mqtt_password = "d,kd,";
const int mqtt_port = 1883;
int buttonState = 0;
const int buttonPin = 2;
WiFiClient espClient;
PubSubClient client(espClient);
// U8GLIB
// U8g2 Constructor List (Frame Buffer)
// The complete list is available here: https://github.com/olikraus/u8g2/wiki/u8g2setupcpp
// Please update the pin numbers according to your setup. Use U8X8_PIN_NONE if the reset pin is not connected
U8G2_ST7920_128X64_F_SW_SPI u8g2(U8G2_R0, 14, 13, 15, U8X8_PIN_NONE);
//U8G2_ST7920_128X64_F_HW_SPI u8g2(U8G2_R0, /* CS=*/ 12, /* reset=*/ U8X8_PIN_NONE); // (Uno and co
// settings for u8g lib and LCD
#define _LCDML_DISP_w 128 // LCD width
#define _LCDML_DISP_h 64 // LCD height
// font settings
#define _LCDML_DISP_font u8g_font_6x13 // u8glib font (more fonts under u8g.h line 1520 ...)
#define _LCDML_DISP_font_w 6 // font width
#define _LCDML_DISP_font_h 13 // font height
// cursor settings
#define _LCDML_DISP_cursor_char "X" // cursor char
#define _LCDML_DISP_cur_space_before 2 // cursor space between
#define _LCDML_DISP_cur_space_behind 4 // cursor space between
// menu position and size
#define _LCDML_DISP_box_x0 0 // start point (x0, y0)
#define _LCDML_DISP_box_y0 0 // start point (x0, y0)
#define _LCDML_DISP_box_x1 128 // width x (x0 + width)
#define _LCDML_DISP_box_y1 64 // hight y (y0 + height)
#define _LCDML_DISP_draw_frame 1 // draw a box around the menu
// scrollbar width
#define _LCDML_DISP_scrollbar_w 10 // scrollbar width (if this value is < 3, the scrollbar is disabled)
// nothing change here
#define _LCDML_DISP_cols_max ((_LCDML_DISP_box_x1-_LCDML_DISP_box_x0)/_LCDML_DISP_font_w)
#define _LCDML_DISP_rows_max ((_LCDML_DISP_box_y1-_LCDML_DISP_box_y0-((_LCDML_DISP_box_y1-_LCDML_DISP_box_y0)/_LCDML_DISP_font_h))/_LCDML_DISP_font_h)
// rows and cols
// when you use more rows or cols as allowed change in LCDMenuLib.h the define "_LCDML_DISP_cfg_max_rows" and "_LCDML_DISP_cfg_max_string_length"
// the program needs more ram with this changes
#define _LCDML_DISP_rows _LCDML_DISP_rows_max // max rows
#define _LCDML_DISP_cols 20 // max cols
// Prototypes
void lcdml_menu_display();
void lcdml_menu_clear();
void lcdml_menu_control();
// Objects
LCDMenuLib2_menu LCDML_0 (255, 0, 0, NULL, NULL); // root menu element (do not change)
LCDMenuLib2 LCDML(LCDML_0, _LCDML_DISP_rows, _LCDML_DISP_cols, lcdml_menu_display, lcdml_menu_clear, lcdml_menu_control);
// LCDML MENU/DISP
// LCDML_0 => layer 0
// LCDML_0_X => layer 1
// LCDML_0_X_X => layer 2
// LCDML_0_X_X_X => layer 3
// LCDML_0_... => layer ...
// For beginners
// LCDML_add(id, prev_layer, new_num, lang_char_array, callback_function)
LCDML_add (0 , LCDML_0 , 1 , "The Panel" , mFunc_feed);
LCDML_add (1 , LCDML_0 , 2 , "ReturnPump" , NULL); // this menu function can be found on "LCDML_display_menuFunction" tab
LCDML_add (2 , LCDML_0_2 , 1 , "OFF" , mFunc_pumpoff);
LCDML_add (3 , LCDML_0_2 , 2 , "ON" , mFunc_pump);
LCDML_add (4 , LCDML_0_2 , 3 , "ReturnPump" , mFunc_goToRootMenu);
LCDML_add (5 , LCDML_0 , 3 , "PowerHead" , NULL); // this menu function can be found on "LCDML_display_menuFunction" tab
LCDML_add (6 , LCDML_0_3 , 1 , "OFF" , mFunc_phoff);
LCDML_add (7 , LCDML_0_3 , 2 , "ON" , mFunc_ph);
LCDML_add (8 , LCDML_0_3 , 3 , "PowerHead" , mFunc_goToRootMenu);
LCDML_add (9 , LCDML_0 , 4 , "ProteinSkimmer", NULL);
LCDML_add (10 , LCDML_0_4 , 1 , "Toggle" , mFunc_pstoggle);
LCDML_add (11 , LCDML_0_4 , 2 , "OFF" , mFunc_psoff);
LCDML_add (12 , LCDML_0_4 , 3 , "ON" , mFunc_ps);
LCDML_add (13 , LCDML_0_4 , 4 , "ProteinSkimmer", mFunc_goToRootMenu);
LCDML_add (14 , LCDML_0 , 5 , "ATO" , NULL); // NULL = no menu function
LCDML_add (15 , LCDML_0_5 , 1 , "OFF" , mFunc_atooff);
LCDML_add (16 , LCDML_0_5 , 2 , "ON" , mFunc_ato);
LCDML_add (17 , LCDML_0_5 , 3 , "ATO" , mFunc_goToRootMenu);
LCDML_add (18 , LCDML_0 , 6 , "Ligths" , NULL);
LCDML_add (19 , LCDML_0_6 , 1 , "OFF" , mFunc_loff);
LCDML_add (20 , LCDML_0_6 , 2 , "ON" , mFunc_l);
LCDML_add (21 , LCDML_0_6 , 3 , "Ligths" , mFunc_goToRootMenu);
LCDML_add (22 , LCDML_0 , 7 , "Control All" , NULL);
LCDML_add (23 , LCDML_0_7 , 1 , "OFF" , mFunc_off);
LCDML_add (24 , LCDML_0_7 , 2 , "ON" , mFunc_on);
LCDML_add (25 , LCDML_0_7 , 3 , "ATOFill" , mFunc_atofill);
LCDML_add (26 , LCDML_0_7 , 4 , "Restart" , mFunc_restart);
LCDML_add (27 , LCDML_0_7 , 5 , "Control All" , mFunc_goToRootMenu);
// Advanced menu (for profit) part with more settings
// Example for one function and different parameters
// It is recommend to use parameters for switching settings like, (small drink, medium drink, big drink) or (200ml, 400ml, 600ml, 800ml) ...
// the parameter change can also be released with dynParams on the next example
// LCDMenuLib_addAdvanced(id, prev_layer, new_num, condition, lang_char_array, callback_function, parameter (0-255), menu function type )
//LCDML_addAdvanced (16 , LCDML_0 , 5 , NULL, "Parameter" , NULL, 0, _LCDML_TYPE_default); // NULL = no menu function
//LCDML_addAdvanced (17 , LCDML_0_5 , 1 , NULL, "Parameter 1" , mFunc_para, 10, _LCDML_TYPE_default); // NULL = no menu function
// LCDML_addAdvanced (18 , LCDML_0_5 , 2 , NULL, "Parameter 2" , mFunc_para, 20, _LCDML_TYPE_default); // NULL = no menu function
// LCDML_addAdvanced (19 , LCDML_0_5 , 3 , NULL, "Parameter 3" , mFunc_para, 30, _LCDML_TYPE_default); // NULL = no menu function
//LCDML_add (20 , LCDML_0_5 , 4 , "Back" , mFunc_back); // this menu function can be found on "LCDML_display_menuFunction" tab
// Example for dynamic content
// 1. set the string to ""
// 2. use type _LCDML_TYPE_dynParam instead of _LCDML_TYPE_default
// this function type can not be used in combination with different parameters
LCDML_addAdvanced (29 , LCDML_0 , 10 , NULL, "" , mDyn_para, 0, _LCDML_TYPE_dynParam); // NULL = no menu function points different tab where i want my temp to go
// Example for conditions (for example for a screensaver)
// 1. define a condition as a function of a boolean type -> return false = not displayed, return true = displayed
// 2. set the function name as callback (remove the braces '()' it gives bad errors)
LCDML_addAdvanced (28 , LCDML_0 , 9 , COND_hide, "screensaver" , mFunc_screensaver, 0, _LCDML_TYPE_default); // this menu function can be found on "LCDML_display_menuFunction" tab
// ***TIP*** Try to update _LCDML_DISP_cnt when you add a menu element.
// menu element count - last element id
// this value must be the same as the last menu element
#define _LCDML_DISP_cnt 29
// create menu
LCDML_createMenu(_LCDML_DISP_cnt);
// SETUP
u8g2.begin();
ArduinoOTA.begin();
// serial init; only be needed if serial control is used
Serial.begin(115200); // start serial
Serial.println(F(_LCDML_VERSION)); // only for examples
pinMode(12, OUTPUT);
pinMode(buttonPin, INPUT);
// LCDMenuLib Setup
LCDML_setup(_LCDML_DISP_cnt);
// Enable Menu Rollover
LCDML.MENU_enRollover();
// Enable Screensaver (screensaver menu function, time to activate in ms)
LCDML.SCREEN_enable(mFunc_screensaver, 10000); // set to 10 seconds
//LCDML.SCREEN_disable();
// Some needful methods
// You can jump to a menu function from anywhere with
//LCDML.OTHER_jumpToFunc(mFunc_p2); // the parameter is the function name
// connecting to a WiFi network
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
Serial.println("Connected to the WiFi network");
//connecting to a mqtt broker
client.setServer(mqtt_broker, mqtt_port);
client.setCallback(callback);
while (!client.connected()) {
String client_id = "esp8266-client-";
client_id += String(WiFi.macAddress());
Serial.printf("The client %s connects to the public mqtt broker\n", client_id.c_str());
if (client.connect(client_id.c_str(), mqtt_username, mqtt_password)) {
Serial.println("Public emqx mqtt broker connected");
Serial.print("failed with state ");
Serial.print(client.state());
delay(2000);
// publish and subscribe
//client.publish(topic, "on");
client.subscribe(hass);
void(* resetFunc) (void) = 0;//declare reset function at address 0
void callback(char *topic, byte *payload, unsigned int length) {
Serial.print("Message arrived in topic: ");
Serial.println(topic);
Serial.print("Message:");
Serial.println("-----------------------");
if ((char)payload[0] == '1') {
digitalWrite(12, HIGH); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is active low on the ESP-01)
digitalWrite(12 , LOW); // Turn the LED off by making the voltage HIGH
u8g2.drawStr( 0, (_LCDML_DISP_font_h * 1), "screen");
// LOOP
// this function must called here, do not delete it
LCDML.loop();
client.loop();
ArduinoOTA.handle();
buttonState = digitalRead(buttonPin);
if (buttonState == LOW) {
// turn LED on:
client.publish(hass, "off");
// check some errors - do not change here anything
# if(_LCDML_glcd_tft_box_x1 > _LCDML_glcd_tft_w)
# error _LCDML_glcd_tft_box_x1 is to big
# endif
# if(_LCDML_glcd_tft_box_y1 > _LCDML_glcd_tft_h)
# error _LCDML_glcd_tft_box_y1 is to big
# endif
the second tab
void mDyn_para(uint8_t line){
u8g2.drawStr( _LCDML_DISP_box_x0+_LCDML_DISP_font_w + _LCDML_DISP_cur_space_behind, (_LCDML_DISP_font_h * (1+line)), "88");
