The problem is I’m getting at least 3 clicks from mouse.press (or mouse.click) on a state change. When I pull the pin low, the cursor goes to the position, but the click is more than 1 click and the cursor stays there for about 2 seconds then is normal again. (normal meaning my logitech mouse can control the cursor again.)
My main goal, - when a pin is pulled low the cursor will click (only once) on a certain position on the screen. The position is determined on what pin I activate.
I searched for weeks with no resolve, can someone confirm they get the same result. I’m not sure what is going on. I appreciate any help.
on my Leonardo:
// Global varibles:
int lastButtonState = LOW; // state of the button last time you checked
int lastButton2State = LOW; // state of the other button last time you checked
boolean mouseIsActive = true; // whether or not the Arduino is controlling the mouse
// initialize mouse control:
// initialize serial communication:
// make pin 2, 3 an input, using the built-in pullup resistor:
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
// read the first pushbutton:
int buttonState = digitalRead(2);
int x;
int y;
// if it's changed and it's high, toggle the mouse state:
if (buttonState != lastButtonState) {
if (buttonState == HIGH) {
// if mouseIsActive is true, make it false;
// if it's false, make it true:
mouseIsActive = !mouseIsActive;
Serial.print("Mouse control state" );
Serial.println(mouseIsActive);
// save button state for next comparison:
lastButtonState = buttonState;
// read the analog sensors:
int sensor1 = analogRead(A0);
delay(1);
int sensor2 = analogRead(A1);
int xAxis = map(sensor1, 0, 1023, -5, 5);
int yAxis = map(sensor2, 0, 1023, -5, 5);
if (mouseIsActive == true) {
Mouse.move(xAxis, yAxis, 0);
// read the second pushbutton:
int button2State = digitalRead(3);
if (button2State != lastButton2State) {
if (button2State == LOW) {
Serial.println("mouse pressed");
Mouse.begin();
for (int z = 1; z <= 10; z++) {
Mouse.move(50, 50);
delay(10);
Mouse.press();
delay(90);
Mouse.release();
delay(50);
Serial.println("mouse released");
// save second button state for next comparison:
lastButton2State = button2State;
