Getting my sensor and dc motors working
:sunglasses: Hi i really could use some help i got a script I'm trying to write and it uses a dc motor and i got the ping sensor mounted on a servos motor anyways this is the script i got so far it does not run the dc motors when i upload it to arduino uno. please help.
don't know what I'm doing wrong
// Using code from the Ping))) example sketch.
#include <Servo.h> // Include servo library
Servo servoLeft; // Declare left, right and Ping))) servos
Servo servoRight;
Servo PingServo;
int minSafeDist = 11 ; // Minimum distance in inches
int pingPin = 9; // PING input on 9 so the last servo port is used.
int centerDist, leftDist, rightDist; // Define distance variables
long duration, inches, cm; // Define variables for Ping)))
int pinI1=8;//define I1 interface
int pinI2=11;//define I2 interface
int speedpinA=9;//enable motor A
int pinI3=12;//define I3 interface
int pinI4=13;//define I4 interface
int speedpinB=10;//enable motor B
int spead =227;//define the spead of motor
void setup() // Built-in initialization block
tone(4, 3000, 1000); // Play tone for 1 second
delay(1000); // Delay to finish tone
PingServo.attach(8);
pinMode(pinI1,OUTPUT);
pinMode(pinI2,OUTPUT);
pinMode(speedpinA,OUTPUT);
pinMode(pinI3,OUTPUT);
pinMode(pinI4,OUTPUT);
pinMode(speedpinB,OUTPUT);
void forward()
analogWrite(speedpinA,spead);//input a simulation value to set the speed
analogWrite(speedpinB,spead);
digitalWrite(pinI4,HIGH);//turn DC Motor B move clockwise
digitalWrite(pinI3,LOW);
digitalWrite(pinI2,LOW);//turn DC Motor A move anticlockwise
digitalWrite(pinI1,HIGH);
void backward()//
digitalWrite(pinI4,LOW);//turn DC Motor B move anticlockwise
digitalWrite(pinI3,HIGH);
digitalWrite(pinI2,HIGH);//turn DC Motor A move clockwise
digitalWrite(pinI1,LOW);
void left()//
void right()//
digitalWrite(pinI2,LOW);//turn DC Motor A move clockwise
void stop()//
digitalWrite(speedpinA,LOW);// Unenble the pin, to stop the motor. this should be done to avid damaging the motor.
digitalWrite(speedpinB,LOW);
void loop(){
LookAhead();
if(inches >= minSafeDist) /* If the inches in front of an object is greater than or equal to the minimum safe distance (11 inches), react*/
forward (121); //Go Forward
delay(110); // Wait 0.11 seconds
else // If not:
servoLeft.writeMicroseconds(1500);
servoRight.writeMicroseconds(1500);
LookAround(); // Check your surroundings for best route
if(rightDist > leftDist) // If the right distance is greater than the left distance , turn right
turnRight (250); // Turn Right
else if (leftDist > rightDist) // If the left distance is greater than the right distance , turn left
turnLeft (250); // Turn Left
backward (250); // Go Backward
delay (250);
void forward(int time) // Forward function
analogWrite(speedpinA,1700);//input a simulation value to set the speed
analogWrite(speedpinB,1300);
delay(time); // Maneuver for time ms
void turnLeft(int time) // Left turn function
analogWrite(speedpinA,1300);//input a simulation value to set the speed
void turnRight(int time) // Right turn function
analogWrite(speedpinB,1700);
void backward(int time) // Backward function
unsigned long ping() {
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW); //Send a low pulse
delayMicroseconds(2); // wait for two microseconds
digitalWrite(pingPin, HIGH); // Send a high pulse
delayMicroseconds(5); // wait for 5 micro seconds
digitalWrite(pingPin, LOW); // send a low pulse
pinMode(pingPin,INPUT); // switch the Pingpin to input
duration = pulseIn(pingPin, HIGH); //listen for echo
/*Convert micro seconds to Inches
cm = microsecondsToCentimeters(duration);
inches = microsecondsToInches(duration);
long microsecondsToInches(long microseconds) // converts time to a distance
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds) // converts time to a distance
return microseconds / 29 / 2;
void LookAhead() {
PingServo.write(25);// angle to look forward 90 degree default
delay(175); // wait 0.175 seconds
ping();
void LookAround(){
PingServo.write(20); // 20∞ angle default
delay(320); // wait 0.32 seconds
ping();
rightDist = inches; //get the right distance
PingServo.write(160); // look to the other side
delay(620); // wait 0.62 seconds
ping();
leftDist = inches; // get the left distance
PingServo.write(90); // 90∞ angle
delay(275); // wait 0.275 seconds
Where are your debug prints?
Where are your observations?
Where are your code tags?
Please put your code in its own window as seen in other posts. This can be done by placing     [code] and [/code]  around the code. This makes it easier for others to read.
Where is the connection drawing?
Weedpharma
Can you please post a copy of your sketch, using code tags?
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
If your sketch is too big, use REPLY rather than QUICK REPLY and it has an attachment facility, so you can post your sketch as an attachment, but try code tags first.
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Tom...... :slight_smile:
so what I'm trying to figure out is just a script to run two dc motors that are controlled by a ping sensor that is mounted on a servos motor, and i got the sensor and servos working but the dc motor script in "void setup" combined with the PingServo.attach(); does not run the two together. hopefully you guys can help me out thank you very much.
Servo servoRight;
Servo PingServo;
void forward()
void backward()//
void left()//
void right()//
void stop()//
void loop(){
  LookAhead();
  else // If not:
    delay (250);
void LookAhead() {
  ping();
void LookAround(){
  ping();
  ping();
Please put your original post code in code box
Weedpharma
I think this is the original script
Servo servoRight;
Servo PingServo;
void forward()
void backward()//
void left()//
void right()//
void stop()//
void loop(){
  LookAhead();
  else // If not:
    delay (250);
void LookAhead() {
  ping();
void LookAround(){
  ping();
  ping();
weedpharma:
Weedpharma
Edit your original post to put it in a code box. It is annoying to have to scroll down pages to see newer posts.
Weedpharma
How many servos do you have and what do they do?
How many ping sensors do you have.
I see 3 servo declarations, but only pingservo is attached.
Yet you use the other two elsewhere in the sketch, why?
Tom..... :slight_smile:
it uses one servo for the ping sensor that moves side to side when it comes near an object and I'm trying to get the dc motors going can someone tip me on why i can't run the dc motor script and the ping sensor attached to the servo.
this is what I'm trying to run
 pinMode(speedpinB,OUTPUT);}
