Getting nRF24L01+ to output +20dBm
I purchased a pair of GT-24 rf transceivers (https://www.amazon.com/dp/B0CM1Y2WSD) based on the nRF24L01+ chip. It includes the PA/LNA chip, has an on-board PCB antenna but also has a ipex antenna connector for an external antenna. I had the two transceivers hooked up to a pair of UNO and verified operation. Just for verification, I hooked up a short cable to the ipex coax connector so I could measure the transmit power with a spectrum analyzer. In the code below, I used the radio.setPALevel(RF24_PA_xxxx); to set the output power between MIN, LOW, HIGH, and MAX. I also used radio.setPALevel(RF24_PA_MAX,1); to enable the LNA, which some documentation indicates that also turns on the power amp. However, I could only read a range of about -18dbm (MIN) to -2dBm (MAX). Nothing I tried would give me the advertised +20dBm output. It appears the PA is not being enabled by anything I have tried.
I had the transceiver connected to an Arduino Uno. I have a 10uf cap installed across the VCC and GND on the transceiver. I tried connecting the VCC to an external power supply, but I did not see any difference from using the UNO 3.3v power.
Is there some method of getting the PA operating to boost the output?
Thanks in advance.
#include <SPI.h>
#include "printf.h"
#include "RF24.h"
#define CE_PIN 7
#define CSN_PIN 8
RF24 radio(CE_PIN, CSN_PIN);
// Let these addresses be used for the pair
uint8_t address[][6] = { "1Node", "2Node" };
bool radioNumber = 1;  // 0 uses address[0] to transmit, 1 uses address[1] to transmit
// Used to control whether this node is sending or receiving
bool role = false;  // true = TX role, false = RX role
float payload = 0.0;
  while (!Serial) {
    // some boards need to wait to ensure access to serial over USB
  if (!radio.begin()) {
    Serial.println(F("radio hardware is not responding!!"));
    while (1) {}  // hold in infinite loop
  // print example's introductory prompt
  Serial.println(F("RF24/examples/GettingStarted"));
  // To set the radioNumber via the Serial monitor on startup
  Serial.println(F("Which radio is this? Enter '0' or '1'. Defaults to '0'"));
  while (!Serial.available()) {
    // wait for user input
  char input = Serial.parseInt();
  radioNumber = input == 1;
  Serial.print(F("radioNumber = "));
  Serial.println((int)radioNumber);
  Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
  // Set the PA Level low to try preventing power supply related problems
  // because these examples are likely run with nodes in close proximity to
  // each other.
  radio.setPALevel(RF24_PA_LOW);  // RF24_PA_MAX is default. // <<< power level set here
  // I also tried radio.setPALevel(RF24_PA_MAX, 1); to enable the LNA
  // I also tried the radio.setRadiation(); function with no change in performance.
  radio.setPayloadSize(sizeof(payload));  // float datatype occupies 4 bytes
  radio.openWritingPipe(address[radioNumber]);  // always uses pipe 0
  radio.openReadingPipe(1, address[!radioNumber]);  // using pipe 1
  if (role) {
    radio.stopListening();  // put radio in TX mode
    radio.startListening();  // put radio in RX mode
}  // setup
  if (role) {
    // This device is a TX node
    unsigned long start_timer = micros();                // start the timer
    bool report = radio.write(&payload, sizeof(float));  // transmit & save the report
    unsigned long end_timer = micros();                  // end the timer
    if (report) {
      Serial.print(F("Transmission successful! "));  // payload was delivered
      Serial.print(F("Time to transmit = "));
      Serial.print(end_timer - start_timer);  // print the timer result
      Serial.print(F(" us. Sent: "));
      Serial.println(payload);  // print payload sent
      payload += 0.01;          // increment float payload
      Serial.println(F("Transmission failed or timed out"));  // payload was not delivered
    // to make this example readable in the serial monitor
    delay(1000);  // slow transmissions down by 1 second
    // This device is a RX node
    uint8_t pipe;
    if (radio.available(&pipe)) {              // is there a payload? get the pipe number that recieved it
      uint8_t bytes = radio.getPayloadSize();  // get the size of the payload
      radio.read(&payload, bytes);             // fetch payload from FIFO
      Serial.print(F("Received "));
      Serial.print(bytes);  // print the size of the payload
      Serial.print(F(" bytes on pipe "));
      Serial.print(pipe);  // print the pipe number
      Serial.print(F(": "));
      Serial.println(payload);  // print the payload's value
  }  // role
  if (Serial.available()) {
    // change the role via the serial monitor
    char c = toupper(Serial.read());
    if (c == 'T' && !role) {
      // Become the TX node
      role = true;
      Serial.println(F("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK"));
    } else if (c == 'R' && role) {
      // Become the RX node
      role = false;
      Serial.println(F("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
}  // loop
This is an interesting one, but I think I would blame the hardware. As far as the software goes, it seems you are doing everything correct.
You could also try the radio.startConstCarrier(RF24_PA_MAX, 40); function to see what kind of output you get there, instead of a single write. There is a scanner example that demonstrates it.
Thanks. I found that later, it would have been helpful when it came to measuring on the spec-an. As it was, the program transmits every second and I was able to find the center frequency and go to zero span to make the measurements.
I have a background in EMC testing. I did not get involved much with intentional radiators, but my coworker was an expert on wireless EMC testing. There were some products that he tested that could only transmit CW for short periods. I have no idea if that is the case with this product. I may try it, though.
I did get a response from the vendor on Amazon. They sent me a link to a chinese website (no english) and recommended installing an app on the website to read the document. No way I am going to install a chinese app on my phone.
