I am reading a hex code from an IR receiver. My objective is that when Arduino receives a code, it should drive ULN2003A to operate a relay. But my problem is that I am not getting 5v from arduino Output pin, the voltmeter reading is only 1.9 v which is not sufficient to drive ULN2003A.
What will be the solution for above problem? Please help.
He doesn't need one if he's quoted the right part number. TI's datasheet declares that, "The ULx2003A devices have a 2.7kΩ series base resistor for each Darlington pair for operation directly with TTL or 5V CMOS devices."
