For some reason I am getting "ovf" for float x = measureTemp(). I have tried moving measureTemp() into void loop() with no success.
// Uses nRF24 lib from here (unzip into "/home/<username>/Arduino/libraries"):
// https://github.com/nRF24/RF24
#include <printf.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Servo.h>
// for the set of available functions see:
// https://github.com/nRF24/RF24/blob/master/RF24.h
RF24 radio(10, 9); // CE, CSN
const unsigned char id[] = "test1"; // 5 bytes
#include <dht_nonblocking.h>
#define DHT_SENSOR_TYPE DHT_TYPE_11
static const int DHT_SENSOR_PIN = 8;
DHT_nonblocking dht_sensor( DHT_SENSOR_PIN, DHT_SENSOR_TYPE );
printf_begin();
if(!radio.begin()){};//module did not respond // defaults to channel 76;
radio.setPALevel(RF24_PA_MAX);//RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH and RF24_PA_MAX
radio.setRetries(0,1);//setRetries(uint8_t delay, uint8_t count)
radio.setDataRate(RF24_1MBPS);//RF24_250KBPS (does not work), RF24_1MBPS, RF24_2MBPS
radio.setChannel(70);// 0..125
radio.enableDynamicPayloads();
radio.enableAckPayload();
radio.setAddressWidth(5);
if(radio.isChipConnected())Serial.println("RF24 connected");else Serial.println("no RF24");
if(radio.testCarrier())Serial.println("testCarrier = true");else Serial.println("testCarrier = false");
if(radio.testRPD())Serial.println("testRPD() = true");else Serial.println("testRPD() = false");
if(radio.isPVariant())Serial.println("isPVariant() = true");else Serial.println("isPVariant() = false");
radio.printDetails();
radio.openWritingPipe(id);
radio.stopListening();
Serial.println("start");
//measures every 4 seconds
static bool measure_environment( float *temperature, float *humidity )
static unsigned long measurement_timestamp = millis( );
if( millis( ) - measurement_timestamp > 3000ul )
if( dht_sensor.measure( temperature, humidity ) == true )
return( true );
return( false );
float measureTemp(){
float temperature;
float humidity;
if(measure_environment(&temperature, &humidity) == true)
return temperature;
float x = measureTemp();//this is producing ovr for some reason???
Serial.println(x);
float y = 11.00; //this is test
bool b = radio.write(&y, sizeof(y));// = false if error, true if delivered
if(!b){
Serial.println("write failed");
}else{
//Serial.print("write ok ... ");
if (radio.isAckPayloadAvailable()) {
// read ack payload and copy data to relevant remoteNodeData array
radio.read(&y, sizeof(y));
Serial.print("ack = ");
//Serial.println(y);
}else{
Serial.println("no ack payload available.");
