Getting Ping Sensor (HC-SR04) to trigger audio response
Hi there!
I’ve been able to successfully get my distance sensor working with the code from this tutorial: http://www.instructables.com/id/Simple-Arduino-and-HC-SR04-Example/
HC-SR04 Ping distance sensor]
VCC to arduino 5v GND to arduino GND
Echo to Arduino pin 13 Trig to Arduino pin 12
Red POS to Arduino pin 11
Green POS to Arduino pin 10
560 ohm resistor to both LED NEG and GRD power rail
More info at: http://goo.gl/kJ8Gl
Original code improvements to the Ping sketch sourced from Trollmaker.com
Some code and wiring inspired by http://en.wikiversity.org/wiki/User:Dstaub/robotcar
#define trigPin 13
#define echoPin 12
#define led 11
#define led2 10
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(led, OUTPUT);
  pinMode(led2, OUTPUT);
  long duration, distance;
  digitalWrite(trigPin, LOW);  // Added this line
  delayMicroseconds(2); // Added this line
  digitalWrite(trigPin, HIGH);
//  delayMicroseconds(1000); - Removed this line
  delayMicroseconds(10); // Added this line
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
  if (distance < 20) {  // This is where the LED On/Off happens
    digitalWrite(led,HIGH); // When the Red condition is met, the Green LED should turn off
  digitalWrite(led2,LOW);
  else {
    digitalWrite(led,LOW);
    digitalWrite(led2,HIGH);
  if (distance >= 200 || distance <= 0){
    Serial.println("Out of range");
  else {
    Serial.print(distance);
    Serial.println(" cm");
Now I’m trying to add in the audio component using this tutorial: http://arduino.cc/en/Tutorial/SimpleAudioPlayer
 Demonstrates the use of the Audio library for the Arduino Due
 Hardware required :
 *Arduino shield with a SD card on CS 4 (the Ethernet sheild will work)
 *Speaker attched to ground and DAC0
 Original by Massimo Banzi September 20, 2012
 Modified by Scott Fitzgerald October 19, 2012
#include <SD.h>
#include <SPI.h>
#include <Audio.h>
  // debug output at 9600 baud
  // setup SD-card
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println(" failed!");
    return;
  Serial.println(" done.");
  // hi-speed SPI transfers
  SPI.setClockDivider(4);
  // 44100 Hz stereo => 88200 sample rate
  // 100 mSec of prebuffering.
  Audio.begin(88200, 100);
  int count=0;
  // open wave file from sdcard
  File myFile = SD.open("test.wav");
  if (!myFile) {
    // if the file didn't open, print an error and stop
    Serial.println("error opening test.wav");
    while (true);
  const int S=1024; // Number of samples to read in block
  short buffer[S];
  Serial.print("Playing");
  // until the file is not finished
  while (myFile.available()) {
    // read from the file into buffer
    myFile.read(buffer, sizeof(buffer));
    // Prepare samples
    int volume = 1023;
    Audio.prepare(buffer, S, volume);
    // Feed samples to audio
    Audio.write(buffer, S);
    // Every 100 block print a '.'
    count++;
    if (count == 100) {
      Serial.print(".");
      count = 0;
  myFile.close();
  Serial.println("End of file. Thank you for listening!");
  while (true) ;
I’m trying to merge these two codes together to get the effect I need. So far this is what I have:
#include <SD.h>
#include <SPI.h>
#include <Audio.h>
#define trigPin 13
#define echoPin 12
#define led 11
#define led2 10
  // setup SD-card
  if (!SD.begin(4)) {
    return;
  int count=0;
  if (!myFile) {
    while (true);
  short buffer[S];
    // Prepare samples
    int volume = 1023;
    count++;
    if (count == 100) {
      Serial.print(".");
      count = 0;
  myFile.close();
  while (true) ;
  else {
  else {
Am I far off? Any help or advice is most appreciated.
Steve
Pins 10,11,12 and 13 are the SPI pins and should not be used for the rangefinder and LEDs. Move those to other pins and change the code to reflect the new setup.
Hey I just wanna ask, have you been successful with your code? Our objectives are the same and I'm searching for solutions and found this thread. I wanna ask you some questions too if you don't mind.
I doubt if ‘svvvvn’ is going to see your question. They only ever posted once and that was 5 months ago.
I would start with their code and change the pins to avoid the conflict between the ultrasonic and LED pins and the SPI pins used to talk to the SD card. Also avoid Pin 4 which is used for the Slave Select pin of the SD card. Try 5, 6, 7, and 8.
Thanks for the reply, mate. So that leaves us 4 pins for the sensors. Is it possible to add pins to the arduino UNO board? We want to use 4 sensors and no LEDs for the actual project but we might use LEDs for testing purposes.
The analog pins can be used as digital pins. PinMode
Looks like the "Simple Audio Player" tutorial (http://arduino.cc/en/Tutorial/SimpleAudioPlayer) is for the DUE and will likely, therefore, not work on the UNO at all. You may need to get something like a WAV Shield or MP3 Shield.
Oh, that's unfortunate. And I dont think there are MP3 and WAV shields available here in our area. Do you think this SD shield would be compatible with UNO or its clones?
http://www.e-gizmo.com/KIT/SD%20%20MMC%20Shield.html
I don't really know how to check compatible shields with our board. Please help.
johnwasser:
I doubt if 'svvvvn' is going to see your question. They only ever posted once and that was 5 months ago.
worked perfectly. thank you very much. I was hammering my head about whats wrong with my code
