is it possible to read the ascii value of the key that's pressed
I'm pressing some keys now. Can YOU read what they are?
The ONLY means of communication between the Arduino and the PC is the serial port, and some application on the PC has to be seeing the keystrokes and talking to the Arduino, via the serial port.
I'm asking is there a way for Arduino to read the pressed key without having to send it trough serial monitor, like when you start Cpp or C console and you just press q and it writes 113.
So I'm asking is there a way to send pressed key directly to arduino.
rxbertx:
is it possible to read the ascii value of the key that's pressed without having to do it trough the serial monitor?
i believe it's getch() or something but since i can't find a way to include conio.h to arduino i don't know what to do :?
You can't use conio.h on an Arduino because it does not come with a console terminal.
Before you can read an ascii value from a keyboard key press you have to specify what the keyboard is connected to and where the ascii value will be displayed.
rxbertx:
Depends on the type of keyboard and where you connect it.
You have to connect the keyboard to the Arduino and NOT THE PC to read the keys from the Arduino and not the PC.
Yes, there are projects that use a PC keyboard with PS/2 connector connected to an Arduino UNO. With a suitable sketch you then can read the keyboard 'scancodes' from the keyboard.
This is the circuit schematics how to connect the keyboards PS/2 connector to an Arduino UNO.
Using the Minicom terminal pgm on Linux with software flow control set sends characters to this sketch without hitting [ENTER], there's still the one second timeout though.
const int ledPin = 9; // the pin that the LED is attached to
// initialize the serial communication:
// initialize the ledPin as an output:
pinMode(ledPin, OUTPUT);
byte brightness;
// check if data has been sent from the computer:
if (Serial.available()) {
// read the most recent byte (which will be from 0 to 255):
brightness = Serial.parseInt();
//set the brightness of the LED:
analogWrite(ledPin, brightness);
Serial.println(brightness);
Works with this too, immediately, no timeout:
int incomingByte = 0; // for incoming serial data
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
// send data only when you receive data:
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
// say what you got:
Serial.print("I received: ");
Serial.println(incomingByte, DEC);
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Jan 1 2014, 17:13:19.
Port /dev/ttyUSB0, 12:34:48
Press CTRL-A Z for help on special keys
I received: 106
I received: 108
I received: 100
I received: 109
I received: 97
I received: 98
I received: 99
I received: 49
I received: 50
I received: 51
