Hi all!
I'm trying to send values to an Arduino Uno from Processing. I've made my brother a circuit that he can use to control a linear actuator and a DMX light. I'm trying to make it so that he can write his own (beginner) Processing code which sends values which correspond with the light and the actuators. The circuit works fine, and I have a working code where I can upload values to it "manually," to change the color and move the actuators. However, I don't know how to change the 8 variables from processing over serial, and make sure that each value goes to it's correct place in the Arduino code.
I've included the Arduino code, minus any of the nonsense I wrote for the serial port. Instead, I've put a note in the void loop() function, where I need to be changing the variables. You can check out the other functions if you like, but the important thing is that they do work when I put the values I want into them. I just need to change the R, G, B, UV, Ac1, Ac2, Ac3, and dtime values via serial, from processing. Can someone point me in the right direction?
// Include headers
#include <DmxSimple.h>
// Define what pins and variables are hooked up to what -----------------------------------------------------------------------------------------
int f1 = 13; //Actuator 1 Forward
int b1 = 12; //Actuator 1 Backwards
int f2 = 11; //Actuator 2 Forward
int b2 = 10; //Actuator 2 Backwards
int f3 = 9; //Actuator 3 Forward
int b3 = 8; //Actuator 3 Backwards
//// Initialize all variables to 0
// Colors range from a value of 0 - 255
int R = 0; //Red
int G = 1; //Green
int B = 0; //Blue
int UV = 0; //UV
// 0 is stop, 1 is forward, 2 is backward
int Ac1 = 0; //Actuator 1
int Ac2 = 0; //Actuator 2
int Ac3 = 0; //Actuator 3
// Can be any value, but timing gets better as "dtime" approaches 0.
int dtime = 0; //time to delay in between actions
// intialize an array to put the values into with a loop
int values[8] = {4,2,2,2,2,2,2,2};
//int pvalues[8] = {32,91,99,10,1,2,0,1};
//int trash = 0;
//Setup the program in the setup function-----------------------------------------------------------------------------------------
/* The most common pin for DMX output is pin 3, which DmxSimple
** uses by default. If you need to change that, do it here. */
DmxSimple.usePin(3);
/* DMX devices typically need to receive a complete set of channels
** even if you only need to adjust the first channel. You can
** easily change the number of channels sent here. If you don't
** do this, DmxSimple will set the maximum channel number to the
** highest channel you DmxSimple.write() to. */
DmxSimple.maxChannel(7);
//Initialize pins to do their thing
pinMode(f1,OUTPUT);
pinMode(b1,OUTPUT);
pinMode(f2,OUTPUT);
pinMode(b2,OUTPUT);
pinMode(f3,OUTPUT);
pinMode(b3,OUTPUT);
//Begin serial communication at 9600 baud
//Do other setup based stuff in here.
//Loop function that goes over and over again-------------------------------------------------------------------------------------
//WE NEED TO CHANGE THE R,G,B,UV,Ac1,Ac2,Ac3, and DTIME values right here!!!!!
//If the values are changed right here simply by editing their values and reuploading, everything works.
//I can even change the values in a loop and do color fades, so speed isn't a problem.
//R,G,B,UV are on a scale of 0-255
//Ac1, Ac2, and Ac3 are 0 for off, 1 for forwards, 2 for backwards.
//dtime is in milliseconds.
//I need to read 8 serial values here, in correct order, and assign them to the R,G,B,etc values.
// Change the color of each one of the channels
changeto(R, G, B, UV);
// Turn on or off the linear actuators
moveto(Ac1, Ac2, Ac3);
//delay for the ever so shortest time
delay(dtime);
//--------------------------------Try not to go past here.-----------------------------------
//Function that instantly changes the light color--------------------------------------------------------------------------------
void changeto(int R, int G, int B, int UV)
//function that instantly changes to another to another light.
if(R <=255 && G <=255 && B <= 255 && UV <= 255) //Error Check
/* Update DMX channel 2 to new brightness */
DmxSimple.write(1, R);
DmxSimple.write(2, G);
/* Update DMX channel 3 to new brightness */
DmxSimple.write(3, B);
/* Update DMX channel 4 to new brightness */
DmxSimple.write(4, UV);
//Check to see if a pre-known array will turn on blink
void checkwithblink()
//Function that moves the linear actuators---------------------------------------------------------------------------------------
void moveto(int Ac1, int Ac2, int Ac3)
// 0 is stop
// 1 is forward
// 2 is backward
//Actuator 1-------------------
if (Ac1 == 1) //Forward
digitalWrite(f1, HIGH);
digitalWrite(b1, LOW);
if (Ac1 == 2) //Backward
digitalWrite(f1, LOW);
digitalWrite(b1, HIGH);
if (Ac1 != 1 && Ac1 != 2)//Stop
//Actuator 2-------------------
if (Ac2 == 1) //Forward
digitalWrite(f2, HIGH);
digitalWrite(b2, LOW);
if (Ac2 == 2) //Backward
digitalWrite(f2, LOW);
digitalWrite(b2, HIGH);
if (Ac2 != 1 && Ac2 != 2) //Stop
//Actuator 3--------------------
if (Ac3 == 1) //Forward
digitalWrite(f3, HIGH);
digitalWrite(b3, LOW);
if (Ac3 == 2) //Backward
digitalWrite(f3, LOW);
digitalWrite(b3, HIGH);
if (Ac3 != 1 && Ac3 != 2) //Stop
If you guys are looking for a good laugh, I can post the processing code - but I'm pretty sure I want to start over on it anyways. It's a steaming pile of dump.
