Getting response code (200) from server for POST (MKRNB.h)
I'm using sketch below to upload data to server with MKR NB1500 and it works ok. How can I get/read response code from server to see if upload was succesfull?
The sketch has this but it doesn't read any response:
if (client.available()) {
Serial.print((char)client.read());
// libraries
#include <MKRNB.h>
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[]     = SECRET_PINNUMBER;
// initialize the library instance
NBClient client;
GPRS gprs;
NB nbAccess(true);
char SerialNum[] = "mds00000";
float gaugeMeasurement = 1.23;
char dataInJSON[500];
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  boolean connected = false;
  // After starting the modem with NB.begin()
  // attach to the GPRS network with the APN, login and password
  while (!connected) {
    if ((nbAccess.begin(PINNUMBER) == NB_READY) &&
        (gprs.attachGPRS() == GPRS_READY)) {
      connected = true;
      Serial.println("Not connected");
  sprintf(dataInJSON, "{\"serNum\": \"%s\",\"mitu1\": \"%.2f\"}", SerialNum, gaugeMeasurement);
  Serial.println(strlen(dataInJSON));
  Serial.println("connecting...");
  if (client.connect("www.xxx.xx",80)) {
    client.println("POST /yyy/index.php HTTP/1.1");
    client.println("Host: www.xxx.xx");
    client.println("Content-Type: application/x-www-form-urlencoded");
    client.print("Content-Length: ");
    client.println(strlen(dataInJSON));
    client.println();
    client.print(dataInJSON);
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.connected()) {
    client.stop();  // DISCONNECT FROM THE SERVER
  Serial.println("done");
  delay(300000); // WAIT FIVE MINUTES BEFORE SENDING AGAIN
The if-available check happens after sending the request, expecting an immediate response; and only happens once. Try this instead
while (client.connected()) {
    delay(5);
  // could also add some time check here to exit the loop
To encourage the web server to disconnect after sending its response, add this as a request header, after the Host
client.println("Connection: close");
Yes, this works :+1: Just need to implement something to stop while-loop like you said.
