I'm trying to send some data from a ESP8266to my API and database. The same exact Json formatted data and url works perfectly when sending from Postman. But for some reason it doesn't work from my ESP8266.
I'm at a loss as to how I can figure this one out ![]()
Any and all help is greatly appreciated!
Below is the kind for the sending of data:
#include <ESP8266HTTPClient.h>
#include <ESP8266WiFi.h>
#include <ArduinoJson.h>
int sense_Pin = 0; // sensor input at Analog pin A0
int value = 0;
int WET = 16; // Wet Indicator at Digital pin D0
int DRY = 2; // Dry Indicator at Digital pin D4
  pinMode(WET, OUTPUT);
  pinMode(DRY, OUTPUT);
  delay(2000);
  WiFi.begin("SSID",
       "PASS");
  while (WiFi.status() != WL_CONNECTED)
  { //Wait for the WiFI connection completion
    Serial.println("Waiting for connection");
  //Serial.print("MOISTURE LEVEL : ");
  value = analogRead(sense_Pin);
  value = value;
  if (WiFi.status() == WL_CONNECTED)
  { //Check WiFi connection status
    StaticJsonBuffer<300> JSONbuffer; //Declaring static JSON buffer
    JsonObject &JSONencoder = JSONbuffer.createObject();
    JSONencoder["PlantId"] = "3";
    JSONencoder["SoilMoistureLevel"] = value;
   Â
    char JSONmessageBuffer[300];
    JSONencoder.prettyPrintTo(JSONmessageBuffer, sizeof(JSONmessageBuffer));
    Serial.println(JSONmessageBuffer);
    HTTPClient http; //Declare object of class HTTPClient
    http.begin("MyApi.net"); //Specify request destination
    http.addHeader("Content-Type", "application/json");   //Specify content-type header
    int httpCode = http.POST(JSONmessageBuffer); //Send the request
    String payload = http.getString();     //Get the response payload
    Serial.println(httpCode); //Print HTTP return code
    Serial.println(payload); //Print request response payload
    http.end(); //Close connection
    Serial.println("Error in WiFi connection");
  delay(30000); //Send a request every 30 seconds
