Getting rid of delay() and for loops; un-delay2 is out
I shaved off a few bytes and added names to the cases. Easy to add more, in any order, as their numeric representation isn't used. The names make it easier when debugging:
// NoBlockUndelayDemo2 2022 by GoForSmoke @ Arduino.cc Forum
// Free for use, May 10, 2022 by GFS. Compiled on Arduino 2.1.0.5
// This sketch shows a general method to get rid of delays in code.
// You could upgrade code with delays to work with add-a-sketch.
// .. adding looped cases
// #include <avr/io.h>  ---  remove this line per Railroader, it's no longer needed
#include "Arduino.h"
enum {LED_ON_500, LED_OFF_500, LED_ON_250, LED_OFF_250, LED_ON_1_SEC, LED_OFF_1_SEC};
const byte ledPin = 13;
unsigned long delayStart;
word delayWait; //65535ms max
const byte indexMax = 12;
byte index;
  Serial.begin( 115200 );
  Serial.println( F( "\n\n\n  Un-Delay Example, free by GoForSmoke\n" ));
  Serial.println( F( "This sketch shows how to get rid of delays in code.\n" ));
  pinMode( ledPin, OUTPUT );
/* The section of the original sketch with delays:
 * digitalWrite( ledPin, HIGH );   --  0
 * delay( 500 );
 * digitalWrite( ledPin, LOW );    --  1
 * delay( 500 );
 * for ( i = 0; i < 12; i++ )
 *   digitalWrite( ledPin, HIGH );   --  2
 *   delay( 250 );
 *   digitalWrite( ledPin, LOW );    --  3
 *   delay( 250 );
 * digitalWrite( ledPin, HIGH );   --  4
 * delay( 1000 );
 * digitalWrite( ledPin, LOW );    --  5
 * delay( 1000 );
byte blinkStep; // state tracking for BlinkPattern() below
void BlinkPattern()
  // This one-shot timer replaces every delay() removed in one spot.
  // start of one-shot timer
  if ( delayWait > 0 ) // one-shot timer only runs when set
    if ( millis() - delayStart < delayWait )
      return; // instead of blocking, the undelayed function returns
      delayWait = 0; // time's up! turn off the timer and run the blinkStep case
  // end of one-shot timer
  // here each case has a timed wait but cases could change Step on pin or serial events.
  switch( blinkStep )  // runs the case numbered in blinkStep
    case LED_ON_500 :
    Serial.println( F( "Case 0 doing something unspecified here at " ));
    Serial.println( delayStart = millis()); // able to set a var to a value I pass to function
    delayWait = 500; // for the next half second, this function will return on entry.
    blinkStep = LED_OFF_500;   // when the switch-case runs again it will be case 1 that runs
    break; // exit switch-case
    case LED_OFF_500 :
    Serial.println( F( "Case 1 doing something unspecified here at " ));
    delayWait = 500;
    blinkStep = LED_ON_250;
    case LED_ON_250 :
    Serial.println( F( "Case 2 doing something unspecified here at " ));
    delayWait = 250;
    blinkStep = LED_OFF_250;
    case LED_OFF_250 :
    Serial.println( F( "Case 3 doing something unspecified here at " ));
    delayWait = 250;
    // this replaces the for-loop in non-blocking code.
    if ( index++ < indexMax ) // index gets incremented after the compare
      index = 0;
      blinkStep = LED_ON_1_SEC;
    }  // how to for-loop in a state machine without blocking execution.
    case LED_ON_1_SEC :
    Serial.println( F( "Case 4 doing something unspecified here at " ));
    delayWait = 1000;
    blinkStep = LED_OFF_1_SEC;
    case LED_OFF_1_SEC :
    Serial.print( F( "Case 5 doing something unspecified here at " ));
    delayWait = 1000;
    blinkStep = LED_ON_500;
void loop()  // runs over and over, see how often
  BlinkPattern();
That's NOT a solution, it's a crappy work-around that'd need a whole special code.
I can get a vt-100 emulator but that's not beginner friendly.
Still not initialized (cf my previous comment) - even more important if you use an enum (which you could force as byte rather than int, and possibly make use it as a type for the state)
Add your name to the comments then and enums cost 2 bytes by default, there's a compiler directive to make them 1 byte.
If there's an enum, it can be the type for blinkStep that then has to be initialized.
// NoBlockUndelayDemoV2R01 2022 by GoForSmoke @ Arduino.cc Forum
// revisions with forum help:
// dlloyd --  added state enums May 11. <--- changed as needed.
unsigned long delayWait;
byte index;
enum blinkStates {LED_ON_500, LED_OFF_500, LED_ON_250, LED_OFF_250, LED_ON_1_SEC, LED_OFF_1_SEC};
blinkStates blinkStep; // state tracking for BlinkPattern() below
  blinkStep = LED_ON_500;  // actual value is 0
 * delay( 500 );
 * delay( 500 );
 *   delay( 250 );
 *   delay( 250 );
 * delay( 1000 );
 * delay( 1000 );
void BlinkPattern()
    case LED_ON_500 :
    Serial.println( F( "LED_ON_500, time " ));
    case LED_OFF_500 :
    Serial.println( F( "LED_OFF_500, time " ));
    delayWait = 500;
    case LED_ON_250 :
    Serial.println( F( "LED_ON_250, time " ));
    delayWait = 250;
    case LED_OFF_250 :
    Serial.println( F( "LED_OFF_250, time " ));
    delayWait = 250;
      index = 0;
    case LED_ON_1_SEC :
    Serial.println( F( "LED_ON_1000, time " ));
    delayWait = 1000;
    Serial.print( F( "LED_OFF_1000, time " ));
    delayWait = 1000;
  BlinkPattern();
Where else can a delay() or serial commands
readBytes()
readBytesUntil()
readString()
readStringUntil()
be hard to unblock?
I often see asks for led strip animations where the animation is just one big function with delays
How baroque does it get?
Based on the topic title, I was a little disappointed in your opening post; I thought that somebody finally explained how to change a for-loop with delay() to something that uses millis().
I did attempt to do so in e.g. Multiple SK6812RGBW controlled by different pins - #17 by sterretje.
typical ask I've seen is that the sketch offers multiple animations and being able to switch between animations at any point in time with a button/remote control/sensor/ or do other stuff whilst the animation goes on
typical state machine based solution
I don't know what change in definition you mean.
Can you post a small example? Perhaps a loop that has a delay in a single case or just runs the same case (over and over, driven by "big wheel" void loop) until a valid input arrives? That will be in the parallel serial text task..
You do know that the 1-shot timer that the function begins with is the millis part?
A lot of very short delays or inputs on interrupts?
Cringe code?
here is an example
(quick search in the forum, I've seen many)
I'm a little confused if this is addressed to me. If so, I'm missing the question; the link that I provided should be the example where a for-loop with delay is converted to a non-blocking approach.
If you leave the mix of mostly println and a few print comands you get sloppy output like this:
LED_ON_250, time
7005
LED_OFF_250, time
7255
LED_ON_1000, time
7505
LED_OFF_1000, time 8505
LED_ON_500, time
9505
LED_OFF_500, time
10005
If you change them to use one line per report you get this output:
LED_ON_500, time 4
LED_OFF_500, time 504
LED_ON_250, time 1004
LED_OFF_250, time 1254
LED_ON_250, time 1504
LED_OFF_250, time 1754
LED_ON_250, time 2004
LED_OFF_250, time 2254
LED_ON_250, time 2504
LED_OFF_250, time 2754
LED_ON_250, time 3004
LED_OFF_250, time 3254
With the one-report-per-line it demonstrates the precision of the timing much more clearly.
byte index;
 * delay( 500 );
 * delay( 500 );
 *   delay( 250 );
 *   delay( 250 );
 * delay( 1000 );
 * delay( 1000 );
void BlinkPattern()
    case LED_ON_500 :
    Serial.print( F( "LED_ON_500, time " ));
    case LED_OFF_500 :
    Serial.print( F( "LED_OFF_500, time " ));
    delayWait = 500;
    case LED_ON_250 :
    Serial.print( F( "LED_ON_250, time " ));
    delayWait = 250;
    case LED_OFF_250 :
    Serial.print( F( "LED_OFF_250, time " ));
    delayWait = 250;
      index = 0;
    case LED_ON_1_SEC :
    Serial.print( F( "LED_ON_1000, time " ));
    delayWait = 1000;
    delayWait = 1000;
  BlinkPattern();
There's a led strip animation change sketch highlighted on Wokwi under Wokwi - Online Arduino and ESP32 Simulator :
https://wokwi.com/arduino/libraries/Adafruit_NeoPixel/buttoncycler
I fiddled with it some, trying to recode some of the animations as state machines:
" I was a little disappointed in your opening post; I thought that somebody finally explained how to change a for-loop with delay() to something that uses millis() ".
I did except that as per the delay code in comment there, the for-next has 2 delays.
You have a different situation
void colorWipe(uint32_t color, int wait)
  for (int i = 0; i < strip.numPixels(); i++)
    strip.setPixelColor(i, color);
    strip.show();
    delay(wait);
okay, how's this? It can be set to start after a period by giving delayWait a value.
int ledNum = 0;
// ........... snippety snip
  strip.setPixelColor( i, color );
  strip.show();
  delayStart = millis(); // starting now
  delayWait = wait;     // wait this long to make the next step
  if ( ledNum++ >= strip.numPixels() )
    ledNum = 0;
I embrace that functions inside the "Big Driving Wheel" void loop() are written to be driven at any time. Treat the world as asynchronous and less can go wrong.
Great work.
In a final version maybe show other millidelay polling.
    if ( millis() - delayStart >= delayWait )
     bla bla bla
  if ( delayWait2 > 0 ) // one-shot timer only runs when set
    if ( millis() - delayStart2 >= delayWait2 )
      delayWait2 = 0; // time's up! turn off the timer and run the blinkStep
     bla2 bla2 bla2
Every "millis timer" has to store its own values. Even button debounce uses a timer.
Timing millis to less than 65.535 seconds can be done with 16 bit type unsigned time variables to save 4 bytes per timer.
One-shots have to turn themselves off.
Repeaters have to reset their start times.
I didn't invent these concepts, they were old when I learned.
The delay code that undelay demo fixes
 * delay( 500 );
 * delay( 500 );
 *   delay( 250 );
 *   delay( 250 );
 * delay( 1000 );
 * delay( 1000 );
 * ------------------------------------------------------------add next or "run at the same time"?
 * for (int i = 0; i < strip.numPixels(); i++)
 *   Serial.print( "pixel " );
 *   Serial.println( i );
 *   delay( wait );
