Yesterday I had some assistance from someone, but it didn't address my main problem. In the code below, I have a bipolar stepper motor attached. I want to attach an ANALOG 2 position switch to my arduino. When the switch is in the off (low) I want the RPM to be 24 but when I click the switch to on (high) I want the code to substitute a different RPM ( say 100). When I turn off the switch I want it to return to the default of 24 rpms....
I cant figure out how to write the code so the RPMS change in response with the switch....Please help....
What kind of command do I need? I'm sure this could help a lot of projects since its covered under the GNU GP License
#include <Stepper.h>
/* Assumptions:
* - stepper motor connected to the 2 phases
* - 8V-30V supply connected to Vin (optional, else Arduino Vin is used)
* This software is licensed under the GNU General Public License (GPL) Version
* 3 or later. This license is described at
* http://www.gnu.org/licenses/gpl.html
* Application Version 1.0 -- October 2010 Rugged Circuits LLC
* http://www.ruggedcircuits.com
// Define how many steps there are in 1 revolution of your motor
#define STEPS_PER_REVOLUTION 200
/* YOU SHOULDN'T HAVE TO CHANGE ANYTHING BELOW THIS POINT */
// constants won't change. They're used here to
// set pin numbers:
const int switchPin = A0; // select the input pin for the fan
const int fanPin = A2; // select the output pin for the fan
const int switch2Pin = A4; // select the input pin for rate
// variables will change:
int switchState= 0; // variable to store the value coming from the sensor
int switch2State = 0;
// Enable (PWM) outputs
#define EN1_PIN 3
#define EN2_PIN 11
// Direction outputs
#define DIR1_PIN 12
#define DIR2_PIN 13
// Fault inputs, active low
#define FAULT1_PIN 5
#define FAULT2_PIN 8
// General-purpose LED's, active high
#define LED0_PIN 9 // For motor A
#define LED1_PIN 10 // For motor A
#define LED2_PIN 16 // For motor B
#define LED3_PIN 17 // For motor B
Stepper stepper(STEPS_PER_REVOLUTION, DIR1_PIN, DIR2_PIN);
// Set initial default values
unsigned RPM = 22;
unsigned PWM = 25;
unsigned DIR = 1;
// initialize the LED pin as an output:
pinMode(fanPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(switchPin, INPUT);
pinMode(switch2Pin, INPUT);
// Configure all outputs off for now
pinMode(EN1_PIN, OUTPUT);
digitalWrite(EN1_PIN, LOW);
pinMode(EN2_PIN, OUTPUT);
digitalWrite(EN2_PIN, LOW);
pinMode(DIR1_PIN, OUTPUT);
digitalWrite(DIR1_PIN, LOW);
pinMode(DIR2_PIN, OUTPUT);
digitalWrite(DIR2_PIN, LOW);
pinMode(LED0_PIN, OUTPUT);
digitalWrite(LED0_PIN, LOW);
pinMode(LED1_PIN, OUTPUT);
digitalWrite(LED1_PIN, LOW);
pinMode(LED2_PIN, OUTPUT);
digitalWrite(LED2_PIN, LOW);
pinMode(LED3_PIN, OUTPUT);
digitalWrite(LED3_PIN, LOW);
// Configure fault inputs with pullups
pinMode(FAULT1_PIN, INPUT);
digitalWrite(FAULT1_PIN, HIGH);
pinMode(FAULT2_PIN, INPUT);
digitalWrite(FAULT2_PIN, HIGH);
// Change from divide-by-64 prescale on Timer 2 to divide by 8 to get
// 8-times faster PWM frequency (976 Hz --> 7.8 kHz). This should prevent
// overcurrent conditions for steppers with high voltages and low inductance.
TCCR2B = _BV(CS21);
// Now enable PWM and start motion
analogWrite(EN1_PIN, PWM);
analogWrite(EN2_PIN, PWM);
stepper.setSpeed(RPM);
[color=red] switchState = analogRead(switchPin); // read the state of the switch value:
switch2State = analogRead(switch2Pin); // check if the switch is tripped.
if (switch2State == HIGH) {
RPM = 100; // speeds up motor rpm's
else {
RPM = 25; //if switch is off then goes back to unsigned rpm =25
[/color]
if (switchState == HIGH) {
analogWrite(fanPin, HIGH); // turn fan on
PWM = 200;
else {
// turn LED off:
analogWrite(fanPin, LOW);
// stop the program for for <sensorValue> milliseconds:
// This is a busy-wait loop until the inter-step time passes
stepper.step(DIR);
// Mirror phase outputs in LED's
digitalRead(DIR1_PIN));
digitalRead(DIR2_PIN));
// Drive fault output LED's as mirror of fault inputs
!digitalRead(FAULT1_PIN));
