Okay, I've done a fair bit of searching here and the interwebs and if there is any easy solution I apologize for not discovering it. A fair number of my projects make use of serial output while I develop them and I'm interested in moving to breadboards and target boards. Can anyone point me towards one or a few accepted "good" methods of getting serial output from my breadboard back to the Serial window in the Arduino IDE? Good could either mean easy to implement or robust, I'm not picky while I research this.
Is this as simple as running pin 0 of my target board to pin 1 of an Uno and pin 1 of my target board to pin 0 of an Uno, placing a serial output sketch on my target chip, and opening a serial window in the IDE? Will an Uno serve as an intermediary in this manner?
ChemE:
Plus either removing the processor on your Uno or forcing it into reset by connected a jumper between RESET and GND. (You may have pins 0 and 1 backwards.)
Yes.
I use an Uno running the TinyISP sketch as the programmer and Knock-Bang running on the target for communications. Works a treat.
You Sir are chock full of win! This worked perfectly! I had mistakenly thought I had to hook Tx to Rx and vice versa but you are right that it is Tx to Tx and Rx to Rx. Again thanks!
