Getting Sketch to Work Correctly is Harder Than I Thought
I'm trying to make a state machine for a project I'm working on. I eventually want 2 buttons: 1 to change color and 1 to change patterns.
The sketch so far compiles perfectly. The serial monitor is there for debugging purposes and it advances thru the colors just like it should.
I've written the sketch to open with the default color red. It does.
Then advance to color green. It does.
But that's where it stops. The strip continues to stay green even though the serial monitor is showing it should be blue, orange, purple, etc. After the last color, the strip should go back to default red. And it does. It changes back to red, then to green and stays stuck at green until red is called again.
#define delay(TIME_DELAY) 30000;
int cycleButton = 2; // cycle colors button pin
int buttonToggleCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
const int ledPin = 6;
const int numLeds = 74;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(74, 6);
void setup() { //this sets the output pins
  pinMode(cycleButton, INPUT);
  pinMode(6, OUTPUT);
  strip.begin();
  strip.show();  // turns leds off
  buttonState = digitalRead(cycleButton);
  if (buttonState != lastButtonState) {
    if (buttonState == HIGH) {    // if the state has changed, increment the counter
      buttonToggleCounter++;    // if the current state is HIGH then the button went from off to on:
    delay(50);    // Delay a little bit to avoid bouncing
  lastButtonState = buttonState; // save the current state as the last state, for next time through the loop
  if (buttonToggleCounter == 1) {
    buttonState = 1;
  if (buttonToggleCounter == 2) {
    buttonState = 2;
  if (buttonToggleCounter == 3) {
    buttonState = 3;
  if (buttonToggleCounter == 4) {
    buttonState = 4;
  if (buttonToggleCounter == 5) {
    buttonState = 5;
  if (buttonToggleCounter == 6) {
    buttonToggleCounter = 0;  //resets counter
  if (buttonToggleCounter == 0) {
    buttonState = 0;   //defaults to red
  switch (buttonState)
      case 1:
        Serial.println("case 1 - should be green");
        delay(TIME_DELAY);
        for(uint32_t i=0; i<numLeds; i++)
            strip.setPixelColor(i,0x008000);
            strip.show();
      case 2:
        Serial.println("case 2 - should be blue");
        delay(TIME_DELAY);
        for(uint32_t i = 0; i > numLeds; i++)
            strip.setPixelColor(i, 0x0000ff);
            strip.show();
      case 3:
        Serial.println("case 3 - should be orange");
        delay(TIME_DELAY);
            strip.setPixelColor(i,0xffa500);
            strip.show();
      case 4:
        Serial.println("case 4 - should be purple");
        delay(TIME_DELAY);
        for(uint32_t i=0; i > numLeds; i++)
            strip.setPixelColor(i,0x800080);
            strip.show();
      case 5:
        Serial.println("case 5 - should be yellow");
        delay(TIME_DELAY);
            strip.setPixelColor(i,0xffff00);
            strip.show();
      default:
        Serial.println("Default color is red");
        delay(TIME_DELAY);
            strip.setPixelColor(i,0xff0000);  // default color is red
            strip.show();
I don't get it. Any help will be greatly appreciated! And in case you need to know, the led strip is: WS2812B 5050 RGB LED Strip 144 LEDs ws2812 IC Individual Addressable 5V
<<< I see!! I knew it had to be something simple. Does it show I've never had formal training on this stuff?
I greatly appreciate your help.
Perhaps you can help answer another question. I've noticed the only colors I get with this strip are the red, green, and blue color. Is it because of the kind of led strip I have or is there something I need to add to the sketch to bring out more colors?
My orange is red, purple is red, yellow is red.
WS2812B 5050 RGB LED Strip 144 LEDs/M ws2812 IC Individual Addressable 5V
