I decoded the ESP8266 stacktrace I was getting in serial monitor:
Decoding stack results
0x40211de4: operator new[](unsigned int) at ../../../../../dl/gcc-xtensa/libstdc++-v3/libsupc++/new_opv.cc line 33
0x40202219: SensorData::read_sensor_data::analogValues() at /var/folders/43/m1qv9zf53q19sqh6h9kg9pz80000gn/T/arduino_build_623045/sketch/read_sensor_data.cpp line 19
0x402022cc: loop() at /Users/seaurchin/Development/Arduino/wemos/soil_sensor_with_ads/soil_sensor_with_ads.ino line 21
0x40207b24: loop_wrapper() at /Users/seaurchin/Library/Arduino15/packages/esp8266/hardware/esp8266/2.5.2/cores/esp8266/core_esp8266_main.cpp line 125
Looks like its pointing to this library read_sensor_data.cpp
You can't define an (automatic) array (or any variable) within a function and pass a usable pointer back to the calling routine. As soon as the function goes out of scope, the storage for the array is released. Easiest is to make the array global. You could also define it a static within the function if you want to do it that way.
Edit
The new operator uses heap storage for your array and this storage may become fragmented. Thus, it is best avoided for small microcontrollers.
Edit 2. (crossed with @JohnWasser)
Contrary to what I implied earlier, storage created with new is not cleaned up. You are responsible for deleting it explicitly. If you use new in a loop without cleaning it up, the heap could become full.
I suspect you are not releasing the memory space that analogValues() allocated. Eventually you run out of memory and crash. When you are done with the array returned by analogValues() you should delete it.
seaurchin:
How should I release the memory space that analogValues() allocated?
I am novoice in arduino c++ .. any help will be greatly appreciated.
analogValues() returns an 'int *' pointing to an array. You didn't include the part of your sketch where the function was called so I don't know what you do with that pointer. You are likely saving it in a variable of type 'int *'. Let's assume you call that variable 'myPointer'. When you are done with the array, I think you are supposed to say "delete [] myPointer;"
int *analogData = SensorData::read_sensor_data::analogValues(); // Returns pointer to allocated int array.
delete [] analogData; // Free the space allocated for the int array.
That should run much longer without running out of memory.
jimLee:
OMG! I must be getting tired. I looked at that and my brain said malloc()
-jim lee
You wouldn’t have gone far wrong. I’ve just looked at the Arduino implementation of the new / delete operators. Just under the surface is malloc() and free()
Considering the hammering that the String class gets here, it is probably best to stay away from them all.
