Getting Started Trouble
I've been trying to install my Uno SMD on XP Home for days. Today I'm documenting in hopes that I can help someone, or get help if needed.
When I first received my board, I mistakingly followed the getting started link from arduino.cc first. This told me to NOT select the drivers/FTDI USB Drivers directory. I have tried on XP Pro and XP Home and have failed after troubleshooting for days.
Today I found that by launching the software (Arduino Alpha 0022) Help > Getting Started, it instructs me to first select drivers/FTDI USB Drivers directory, then repeat. The first time will give me "USB Serial Converter" found, then the second time "USB Serial Port" will be found. I just tried that procedure and it seems I'm still not able to install, though the errors are a bit different.
Here is my next run,
  1. I went to Device Manager >
  2. Go to Start > Control Panel > Add Hardware
  3. Click Next
  4. Select No, not this Time. Click Next
  5. Select Install from a list or specific location (Advanced). Click Next
  6. Select Search for the best driver in these locations.
    Select Include this location in the search:
    Browse to "C:\Documents and Settings<windows user>\Desktop\arduino-0022\arduino-0022\drivers\FTDI USB Drivers"
    Click Next
I received window titled "Cannot Install this Hardware" - The hardware was not installed because the wizard cannot find the necessary software.
  1. Clicked Finish
I received "Add Hardware Wizard" window stating "This wizard is searching for hardware that has been connected to your computer recently but has not yet been installed."
I received another dialog window titled "Files Needed". Stating "The file 'atapi.sys' on Windows XP Home Edition Service Pack 3 CD is needed"
I received the above error message previously, but also received 'usbser.sys' needed. I found the hotfix, but tells me my current SP3 is more recent.
  1. Click Cancel since I don't know where atapi.sys might be in the file system.
  2. Bang head against desk furiously.
  3. Repeat
Someone Please Help!!!!!
Have to add..... step 1 continues... right clicking Other Devices > Arduino Uno, then Driver > Uninstall AND IDE ATA/ATAPI controllers > IDE Channel > Drivers > Uninstall
The Uno does not need FTDI drivers as it does not have the FTDI chip. Forget about ATAPI, that's for ATA disk controllers.
I'm not a Windows expert, suggest you uninstall, reinstall the Arduino software and go through the checklists.
Thanks Mark. However I did right click Arduino and the IDE icons in Device Manager, click properties > drivers > uninstall. And it uninstalled both (i didn't yet try a restart at this point)
When I try the next time, I completely remove the FTDI folder from the arduino directories, just to make sure windows doesn't pick from that sub dir. I point to the /drivers dir and still no luck!!!
I have had this for over a month and still have not been able to load a sketch ;-<
I'm going to try this on Ubuntu
