Hi
I've a larger project where I'm using a function to return an array for later use. First I got strange returnvalues from the function, like 512 instead of 0 or 1. When I commented almost all code in the function it worked.
I've broken it down to this, and it seems to be when adding digitalRead the problem begins.
int* arr0[13];
const int buttonPin=3;
int buttonState=0;
void setup(){
pinMode(buttonPin, INPUT);
// the loop routine runs over and over again forever:
void loop(){
arr0[0]=myFunction(5,7,buttonPin);
Serial.println(arr0[0][1]);
int* myFunction(int var0, int var1, int var2){
buttonState=digitalRead(buttonPin);
int arr1[3];
arr1[0]=var0;
arr1[1]=var1;
arr1[2]=var2;
return arr1;
I see the code as follow:
I define an array named arr0 with length 13
I call the function with myFunction(5, 7, buttonPin) and save returnvalue at index 0 in array arr0
I want to print out number 7 that I've passed to myFunction. It should be placed at arr0[0][1]?
buttonPin is 3 as stated earlier in code
I then define a array named arr1 with length 3
index 0 is filled with 5
index 1 is filled with 7
and index 2 is filled with buttonPin (3)
arr1 is returned
Why am I not getting the value that I'm looking for?
Best Regards
Niclas
