Getting string value out of function
I have been used to programming MCUs in Basic, so transferring over to C++ has not been an easy journey.
I have a piece of code where I am trying to get the value of a string back into the main loop.
In basic this would be easy with a Gosub command, but i cannot figure it out in Arduino.
My structure looks like this and it is the content of the 'message' string that I am trying to get back into the main loop.
I have tried various 'return' functions without success.
Is anybody able to assist please so I can goto bed :slight_smile:
Many thanks.
  temperature();          //  Calls Temperature function
  ...lots more code
void temperature()
  ...lots more code
     String message;
     message = inString.substring(startCommand+1, stopCommand);
     Serial.println(message);
Make the function return a string instead of void and put
return message;
at the end.
Then in the loop, create a variable to hold the string and use the function to get it.
String temperature_message = Temerature();
That absolutely will NOT work. When temperature ends, the message variable goes out of scope, which means that the memory it was using is available to be reused. Returning a pointer to that space is not a great idea.
What you do need to do is pass the function a reference to a String object that you want it to write to.
void temperature(String &dest)
   dest = inString.substring(startCommand+1, stopCommand);
Then call the function:
   String junk;
   temperature(junk);
   Serial.print("temperature returned: ");
   Serial.println(junk);
One thing that will trip you up is that the IDE fails to create function prototypes for functions that use reference arguments. You will either need to define the function before any calls to the function or create the function prototype yourself.
On the other hand, since everything else that temperature() deals with is a global variable, it doesn't really make sense to try to make it deal with local variables, too.
