getting switch case results to print to LCD
Hi all I am designing a water level sensor. I used a map function to take the voltage divider input on A(1) from 0-1023 to 0-30. I then used a switch case to (hopefully) print out how many gallons of water are remaining but my LCD will ONLY print a 0 and im not sure why? It does not change with the input that is being read in on the analog input on A1. It does properly print "Water remainging:" and "Gallons" just not the proper number!! Here is my code.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * LCD VSS pin to ground
 * LCD VCC pin to 5V
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
 //int analogPin = 1;     // potentiometer wiper (middle terminal) connected to a
 int val = analogRead(1);           // variable to store the value read
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 0);
   // Print a message to the LCD.
  lcd.print("Water Remaining:");
  lcd.setCursor(3, 1 );
  lcd.print("Gallons");
 int waterLevel = map(val, 0, 1023, 0, 1);    // read the input pin
  switch(waterLevel){
     case 0:
       lcd.setCursor(0, 1 );
       lcd.print("0");
    case 1:
       lcd.print("1");
    case 2:
       lcd.print("2");
    case 3:
       lcd.print("3");
    case 4:
       lcd.print("4");
    case 5:
       lcd.print("5");
    case 6:
       lcd.print("6");
    case 7:
       lcd.print("7");
    case 8:
       lcd.print("8");
    case 9:
       lcd.print("9");
    case 10:
       lcd.print("10");
    case 11:
       lcd.print("11");
    case 12:
       lcd.print("12");
    case 13:
       lcd.print("13");
    case 14:
       lcd.print("14");
    case 15:
       lcd.print("15");
    case 16:
       lcd.print("16");
    case 17:
       lcd.print("17");
    case 18:
       lcd.print("18");
    case 19:
       lcd.print("19");
    case 20:
       lcd.print("20");
    case 21:
       lcd.print("21");
    case 22:
       lcd.print("22");
    case 23:
       lcd.print("23");
    case 24:
       lcd.print("24");
    case 25:
       lcd.print("25");
    case 26:
       lcd.print("26");
    case 27:
       lcd.print("27");
    case 28:
       lcd.print("28");
    case 29:
       lcd.print("29");
    case 30:
       lcd.print("30");
If anyone can help that would be awesome! I am also taking any suggestions on how to improve my code or any better ways to do this. Thanks guys and gals.
LCD_display.ino (4.22 KB)
Why your analogRead(1) is out side of the loop function
it should put inside the loop function like this
val = analogRead(1); // update value
and this:
should be
int waterLevel = map(val, 0, 1023, 0, 30);
Bill thanks for the advice ill give it a try tomorrow! I'm not sure why I put it up there because as it is it will only analog read the first time through the code. Thanks for pointing that out.
Qdeathstar I had my code commented out just trying to troubleshoot with case 0 and 1. When I was actually trying the whole code I had it as you suggested it should be with the 30. It didn't work with it like that but Thanks for the input though!
