I'm getting following error on arduino IDE:
/usr/local/bin/arduino-cli compile --fqbn esp32:esp32:esp32doit-devkit1:DebugLevel=none,FlashFreq=80,UploadSpeed=921600 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/568862994/build --build-path /tmp/arduino-build-8339931FB8AA70A11159A82F2120A7AA --library /mnt/create-efs/webide/13/e8/13e89aac54e7d22b04665ae02741cfff:farhan74/libraries_v2/SimpleTimer --library /mnt/create-efs/webide/13/e8/13e89aac54e7d22b04665ae02741cfff:farhan74/libraries_v2/TimerOne /tmp/568862994/button_test_aug16a
Sketch uses 952626 bytes (72%) of program storage space. Maximum is 1310720 bytes.
Global variables use 41384 bytes (12%) of dynamic memory, leaving 286296 bytes for local variables. Maximum is 327680 bytes.
In file included from /tmp/568862994/button_test_aug16a/button_test_aug16a.ino:27:0:
/home/builder/.arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/Wire/src/Wire.h: In function 'void mpu_read()':
/home/builder/.arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/Wire/src/Wire.h:102:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
uint8_t requestFrom(int address, int size, int sendStop);
/home/builder/.arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/Wire/src/Wire.h:97:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint16_t, uint8_t, bool)
uint8_t requestFrom(uint16_t address, uint8_t size, bool sendStop);
Upload started
Programming with: Serial
Flashing with command:C:/Users/hp/.arduino-create/esp32/esptool_py/3.0.0/esptool.exe --chip esp32 --port COM9 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 C:/Users/hp/AppData/Local/Temp/extrafiles176899786/tools/partitions/boot_app0.bin 0x1000 C:/Users/hp/AppData/Local/Temp/extrafiles176899786/tools/sdk/bin/bootloader_dio_80m.bin 0x10000 C:/Users/hp/AppData/Local/Temp/arduino-create-agent657710423/button_test_aug16a.bin 0x8000 C:/Users/hp/AppData/Local/Temp/extrafiles176899786/button_test_aug16a.partitions.bin
usage: esptool write_flash [-h] [--erase-all]
[--flash_freq {keep,40m,26m,20m,80m}]
[--flash_mode {keep,qio,qout,dio,dout}]
[--flash_size FLASH_SIZE]
[--spi-connection SPI_CONNECTION] [--no-progress]
[--verify] [--encrypt]
[--ignore-flash-encryption-efuse-setting]
[--compress | --no-compress]
<address> <filename> [<address> <filename> ...]
esptool write_flash: error: argument <address> <filename>: [Errno 2] No such file or directory: 'C:/Users/hp/AppData/Local/Temp/arduino-create-agent657710423/button_test_aug16a.bin'
