Getting the time
Am have been working on a control for my pool. After much cursing, i have it worked out where i can control i t manually with 3 buttons (Pump, Heat, Light) or with a web page. It is working quite well in fact.
My next hurdle is making a timer. To do this, i will need set the time in Arduino which i have been able to do using NTP time sync.
I have the time.h library installed and from what i have read, there should be a function called setTime(). I don't seem to be able to get this to work. When i try to use it the IDE throws and error "no matching call".
My issue is this: I want to store the current time and start time in a variable so that i can set the pump to start a 6am and shut off at 1pm. For the sake of argument, lets say we call the variables "startTime" "and curTime"
if((curTime)>=(startTime) && (curTime)<(endTime))
digitalWrite(5, HIGH);  // pump is running on D5
So what i am trying to do figure out how to set the value of (curTime) to the current time.
Thanks in advance.
Google: "Arduino RTC"
You need more than just an arduino to do accurate timer operations over long periods (more than a few seconds).
Post the complete code.
setTime() is indeed in the Time library and works.
What data type is curTime?
the type will be int. int curTime;
As far as the setTime function, i am using the updated version of time.h Apparently i am not the only one who has had this issue however I can't seem to find a solution for it.
needahobby:
That's a problem. Use the time_t data type from the Time.h library. This is a 32-bin unsigned integer, basically Unix epoch time, seconds since 01Jan1970.
#include <Time.h>
time_t curTime;
When i add what you suggested, i still get the same error indicating that time_t was not declared.
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
#include <time.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ   60
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 24); // IP address, may need to change depending on network
EthernetServer server(80);  // create a server at port 80
File webFile;               // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0;              // index into HTTP_req buffer
boolean LED_state[4] = {0}; // stores the states of the LEDs
int pumpSw = (31);
int lightSw = (32);
int heatSw = (33);
//TIMER VARIABLES=============================================================
int curTime;
int startTime;
int endTime;
  // disable Ethernet chip
    pinMode(10, OUTPUT);
    digitalWrite(10, HIGH);
    Serial.begin(9600);       // for debugging
    // initialize SD card
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
        return;    // init failed
    Serial.println("SUCCESS - SD card initialized.");
    // check for index.htm file
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;  // can't find index file
    Serial.println("SUCCESS - Found index.htm file.");
    // switches on pins 2, 3 and 5
    pinMode(2, INPUT);
    pinMode(3, INPUT);
    //pinMode(4, INPUT);
    //pinMode(5, INPUT);
    pinMode(31,INPUT);
    pinMode(32,INPUT);
    pinMode(33,INPUT);
    // LEDs
    pinMode(4, OUTPUT);
    pinMode(5, OUTPUT);
    pinMode(6, OUTPUT);
    pinMode(7, OUTPUT);
    pinMode(8, OUTPUT);
    pinMode(9, OUTPUT);
    pinMode(50,OUTPUT);
    pinMode(22,OUTPUT);   //to power breadboard
    Ethernet.begin(mac, ip);  // initialize Ethernet device
    server.begin();           // start to listen for clients
    Serial.print("IP Address is");
        Serial.println(Ethernet.localIP ());
        Serial.println(digitalRead(2));
        digitalWrite(22, HIGH);
//TIMER ON/OFF CODE===========================================================
 /* if((curTime)>=(startTime) && (curTime)<(endTime))
  EthernetClient client = server.available();  // try to get client
    if (client) {  // got client?
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {   // client data available to read
                char c = client.read(); // read 1 byte (character) from client
                // limit the size of the stored received HTTP request
                // buffer first part of HTTP request in HTTP_req array (string)
                // leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
                if (req_index < (REQ_BUF_SZ - 1)) {
                    HTTP_req[req_index] = c;          // save HTTP request character
                    req_index++;
                // last line of client request is blank and ends with \n
                // respond to client only after last line received
                if (c == '\n' && currentLineIsBlank) {
                    // send a standard http response header
                    // remainder of header follows below, depending on if
                    // web page or XML page is requested
                    // Ajax request - send XML file
                    if (StrContains(HTTP_req, "ajax_inputs")) {
                        // send rest of HTTP header
                        client.println("Content-Type: text/xml");
                        client.println("Connection: keep-alive");
                        client.println();
                        SetLEDs();
                        // send XML file containing input states
                        XML_response(client);
                    else {  // web page request
                        client.println("Content-Type: text/html");
                        client.println();
                        // send web page
                        webFile = SD.open("index.htm");        // open web page file
                        if (webFile) {
                            while(webFile.available()) {
                                client.write(webFile.read()); // send web page to client
                            webFile.close();
                    // display received HTTP request on serial port
                    Serial.print(HTTP_req);
                    // reset buffer index and all buffer elements to 0
                    req_index = 0;
                    StrClear(HTTP_req, REQ_BUF_SZ);
                // every line of text received from the client ends with \r\n
                if (c == '\n') {
                    // last character on line of received text
                    // starting new line with next character read
                else if (c != '\r') {
                    // a text character was received from client
                    currentLineIsBlank = false;
            } // end if (client.available())
        } // end while (client.connected())
        delay(1);      // give the web browser time to receive the data
        client.stop(); // close the connection
    } // end if (client)
 // Manual pump control-----------------------------------------------------
   if (digitalRead(pumpSw)==1)
        if(digitalRead(5)==LOW)
        LED_state[0] = 1;  // save LED state
        else if (digitalRead(5)==HIGH)
        LED_state[0] = 0;  // save LED state
        digitalWrite(5, LOW);
  // Manual light control-----------------------------------------------------
   if (digitalRead(lightSw)==1)
        if(digitalRead(6)==LOW)
        LED_state[1] = 1;  // save LED state
        digitalWrite(6, HIGH);
        else if (digitalRead(lightSw)==1)
        LED_state[1] = 0;  // save LED state
        digitalWrite(6, LOW);
   // Manual heat control-----------------------------------------------------
   if(digitalRead(5)==HIGH)
     if (digitalRead(heatSw)==1)
        if(digitalRead(7)==LOW)
        LED_state[2] = 1;  // save LED state
        digitalWrite(7, HIGH);
        else if (digitalRead(heatSw)==1)
        LED_state[2] = 0;  // save LED state
        digitalWrite(7, LOW);
// checks if received HTTP request is switching on/off LEDs
// also saves the state of the LEDs
==============REMAINDER OF CODE DELETED DUE TO SIZE > 9500 CHARACTERS=========================
needahobby:
Impossible to check your code, it was truncated. It's also a lot of code to check :expressionless:
Have you tried one of the simple examples that come with the Time library? Are you sure the Time library is installed correctly? Seems I remember that the way it is zipped, it may end up down one folder level from where it should be.
It should be in
sketchbook\libraries\Time
and should contain an Examples folder, DateStrings.cpp, Time.cpp, Time.h, keywords.txt and Readme.txt.
Be sure it's not in
sketchbook\libraries\Time\Time ... or something similar
That could be the problem but if i try to call the setTime() function in the time example, I still get an error.
question:
If i add a library such as time into the libraries. This contains time.h. Does this now mean that time.h is available for any sketch or just those that are in the libraries>time folder?
Thanks for all the help
needahobby:
If the examples give the same error, that sure sounds like the library is not installed correctly.
Any sketch. Your sketches don't belong in the libraries folder. If you write libraries, then they can go in the libraries folder.
