Hi! This question I am asking may not be relevant to Arduino as the calculations and done in the Android Studio side. I am currently doing the turning part for the robot. Currently, I have calculated the angle between 2 latitude and longitude points. However, I do not know how to make the angle such that when moving forward, my angle will be between 0 to 45 degrees. As of now, the angle for moving forward can be 0, 90, 180 or 270 degrees depending on which direction I go. I get the angle from Android application which is using atan2 to calculate the angle. The codes below shows how I get the angle using atan2.
public int bearing(float lat1, float lon1, float lat2, float lon2, float previousDegree){
double latitude1 = Math.toRadians(lat1);
double longitude1 = Math.toRadians(lon1);
double latitude2 = Math.toRadians(lat2);
double longitude2 = Math.toRadians(lon2);
double brng = Math.atan2((latitude2-latitude1),(longitude2-longitude1));
double atan2 = Math.toDegrees(brng);
if (atan2 < 0.0)
atan2 += 360;
degree = (float)atan2;
return (int)(atan2-previousDegree);
The codes below are the codes for turning written in Arduino:
if (angleDouble > -45 && angleDouble < 45){ // forward
clearAll();
delay(30);
Serial.println("forward");
//forward();
//delay(delayTime);
if (angleDouble > 45 && angleDouble < 135){
clearAll();
delay(30);
Serial.println("turn left");
//turnLeft(75);
//delay(360/2180*90); //* 90 because it makes a 90 degree turn
if (angleDouble > -135 && angleDouble < -45){ // if angle Double is negative change positive
clearAll();
delay(30);
Serial.println("turn right");
//turnRight();
I hope someone can give me some advice. Thank you!
