Hi there
First I have to say Im new to programming and Arduino
Im working on a battery box as a school project. The idea is to determine batteries on their weight.
I have RGB LED that is changing color according to the weight and to servos.
First servo opens a flap and the second is pushing the batteries.
The problem is that I can get the LED working but once I uncomment the servo part, the LED won’t work as desired. It will only turn red and the servo is working a bit odd too…
I’ve been stuck in this for days =( Hopefully I can get some help here
Thanks in advance
There is a **RGB LED** which gets the color GREEN when the device
is ready for input, YELLOW when it is processing and RED when
the input is not recognized as a battery.
**One infrared sensor** for detecting an incoming object.
**Two servos**. One for opening and closing the flap at the end of the tube.
The second for turning the bowl on the scale in one or the other direction.
Finally there is a **weight scale** sending information to Arduino in steps 0-1023.
const int redPin = 11; // R petal on RGB LED module connected to digital pin 11
const int greenPin = 9; // G petal on RGB LED module connected to digital pin 9
const int bluePin = 10; // B petal on RGB LED module connected to digital pin 10
const int buttonPin1 = 2; // the infrared sensor
int AAAVal,AAVal,CVal,DVal = 0; // used to store battery values
int button1State = 0; // variable for storing the value of the infrared sensor
//#include <Servo.h>
//Servo servo1, servo2;
Creates a servo object to control a servo.
servo1 = flap. servo2 = turning the scale bowl
Serial.begin(9600); // initialize serial communication at 9600 bits per second:
pinMode(redPin, OUTPUT); // sets the redPin to be an output
pinMode(greenPin, OUTPUT); // sets the greenPin to be an output
pinMode(bluePin, OUTPUT); // sets the bluePin to be an output
pinMode(buttonPin1, INPUT); // the infrared sensor in the final version
//servo1.attach(5); // attaches the servo on pin 5 to the servo object
//servo2.attach(6); // attaches the servo on pin 6 to the servo object
// Ready for input
button1State = digitalRead(buttonPin1); // read the state of the pushbutton/infrared sensor value
//int servo1Pos = 180; // servo1, flap initial position
//int servo2Pos = 80;// servo2, initial position
int sensorValue = analogRead(A0); // the analog reading (which goes from 0 - 1023) weight measuring
AAAVal = constrain(sensorValue, 50, 200);// weight(step) value of an 'AAA' battery
AAVal = constrain(sensorValue, 210, 232);// weight(step) value of an 'AA' battery
CVal = constrain(sensorValue, 243, 289);// weight(step) value of a 'C' battery
DVal = constrain(sensorValue, 295, 360);// weight(step) value of a 'D' battery
boolean runWeight = false;
if (button1State == LOW) // If object passes infrared sensor in the tube
// servo1.write(servo1Pos = 20);// Open flap
yellow();
delay (1000);
runWeight = true;
//servo1.write(servo1Pos = 90);// Close flap
//delay (20);
else // If nothing enters the tube
green();// turn ON green color
// Object landing in the bowl!
while (runWeight == true){
// delay (1500);
if (sensorValue == AAAVal)// if object weighs as an AAA battery
Serial.println("AAA battery");
yellow();delay(1000);
//servo2.write(servo2Pos = 160);
delay(20); // delay for 0.2 second(s)
//servo2.write(servo2Pos = 80);
//delay(20);
runWeight = false;
else if (sensorValue == AAVal) // if object weighs as an AA battery
Serial.println("AA battery");
delay(20);
runWeight = false; // delay for 1.5s second(s)
//servo2.write(servo2Pos = 20);
//delay(1500); // delay for 1.5 second(s)
else if (sensorValue == CVal) // if object weighs as a C battery
Serial.println("C battery");
delay (20);
runWeight = false;
else if (sensorValue == DVal) // if object weighs as a D battery
Serial.println("D battery");
delay(20);
runWeight = false;
// if there is some load on the scale and weight is not among the defined values
else if (sensorValue != 0 & sensorValue != 1 & sensorValue != 2)
Serial.println("NOT recognized as a battery");
red(); // turn the RGB LED Red
delay (800);
//servo2.write(servo2Pos = 15); // battery denied
//delay(500); // delay for 0.5 second(s)
//delay(20); // delay for 0.2 second(s)
runWeight = false;
green(); // when nothing is on the weight, the RGB LED turns green again
//delay(500);
runWeight = false;
runWeight = false;
Serial.println(sensorValue);
delay(200);
void green(){
analogWrite (redPin, 0);
analogWrite (greenPin, 200);
analogWrite (bluePin, 0);
//delay (2000);
void blue(){
// turn ON blue color
analogWrite (greenPin, 0);
analogWrite (bluePin, 255);
void red(){
// turn ON red color
analogWrite (redPin, 255);
//delay (2000);
void yellow(){
// turn ON yellow color
analogWrite (greenPin, 50);
delay (2000);
