Getting Virtual Wire and SdFat to work together, storing messages on microSD
Hi.
As part of a university summer project I need to wirelessly transfer some data from one Arduino board with a microSD attached to another Arduino board with microSD. I have had success with the transmission side of things and have working code that can read text from a txt file and then transmit whatever is read. I know this code works fine as I have seen the transfer on the receiving serial monitor.
My problem is with the next stage - writing the received data to a microSD. I am using the Virtual Wire library for the wireless and SdFat for the storage. My code on the receiving Arduino is as follows:
//Attach receiver module facing outwards from pins 2 to 5 for no breadboard setup
#include <VirtualWire.h>
#include <SdFat.h>
//Virtual Wire initialisations
const int receive_pin = 3;
const int transmit_en_pin = 7;
const int Vpin = 2;
const int GND = 5;
//SdFat initialisations
SdFat sd;
SdFile myFile;
const int chipSelect = 4;
    Serial.begin(9600);	// Debugging only
    Serial.println("setup");
    // Initialise the IO and ISR
    vw_set_rx_pin(receive_pin);
    vw_set_ptt_pin(transmit_en_pin);
    vw_set_ptt_inverted(true); // Required for DR3100
    pinMode(Vpin, OUTPUT); // Sets up pins for use
    pinMode(GND, OUTPUT);
    digitalWrite(Vpin, HIGH);  // Sets up pin voltage levels
    digitalWrite(GND, LOW);
    if (!sd.begin(chipSelect, SPI_HALF_SPEED)) //  Try to begin communication with microSD
     sd.initErrorHalt(); // If fails then error
    if (!myFile.open("rx.txt", O_RDWR | O_CREAT | O_AT_END)) // Try to open file for write
     sd.errorHalt("opening rx.txt for write failed");  // If fails then error
    vw_setup(2000);	 // Bits per sec
    vw_rx_start();       // Start the receiver PLL running
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // If a message is received...
      for (int i = 0; i < buflen; i++) //For each received byte...
            Serial.print((char)buf[i]);
	    myFile.println((char)buf[i]); //Write single byte to to myFile, rx.txt
      myFile.close();
The problem is that received messages do not appear on the receiving serial monitor nor the receiving microSD (though the file "rx.txt" is created, it is just blank).
Is there some blaring misuse of the libraries here? I'm new to Arduinos but my transmission code is written in a similar way and works fine.
Any and all advice here would be appreciated and if I have missed out information then please ask. Thanks.
EDIT: The RF modules used are eBay's finest (433MHZ RF Transmitter and Receiver Pair Wireless Arduino Pi Pic UK L4a302 for sale online | eBay) at £2. They are cheap but functional and I have had no issues with them.
Here is the code for my transmitter. If has any bad practice I'd appreciate knowing but it does work (I swear!).
//Connect transmitter facing inwards to pins A3, A4 and A5
#include <SdFat.h>
SdFat sd;
SdFile myFile;
const int led_pin = 11;
const int transmit_pin = A5;
const int receive_pin = 2;
const int transmit_en_pin = 3;
    vw_set_tx_pin(transmit_pin);
    pinMode(A3, OUTPUT);
    pinMode(A4, OUTPUT);
    pinMode(A5, OUTPUT);
    digitalWrite(A3, LOW);
    digitalWrite(A4, HIGH);
  while (!Serial) {}  // wait for Arduino
  if (!sd.begin(chipSelect, SPI_HALF_SPEED)) sd.initErrorHalt();
  // open the file for reading:
  if (!myFile.open("pack.txt", O_READ)) {
    sd.errorHalt("File read failed!");
  char data;
  while ((data = myFile.read()) >= 0){
    char msg[1] = {data};
    delay(100);
    vw_send((uint8_t *)msg, 1);
    vw_wait_tx(); // Wait until the whole message is gone
    delay(100);
  // close the file:
  myFile.close();
In your receiver code, you are opening myfile in setup();
and according to your code after receiving any data (vw_get_message(buf, &buflen)) it writes to file and close the myfile.
Now, once again when you receive any message you are not able to write to file because it is already closed.
so you need to reopen the file once you receive the data and after writing to file close it.
Hi Bijendra, moving both of the if statements and the file close to be within the for loop has got it writing!
The only problem now is that only the first array of bytes transferred gets written. I imagine that indicates that I have put something in the for loop that shouldn't be there?
Right now the code is:
#include <SdFat.h>
const int Vpin = 2;
const int GND = 5;
SdFat sd;
SdFile myFile;
          myFile.close();
Thanks a lot for the help :slight_smile:
in your code, Inside
// for every  iteration you are initializing the the sd card, opening and closing  the myfile.
// that might b creating a problem( i dont have sd card to test.)
          myFile.close();
you need to do like this:
        myFile.close();
Thank you, that worked perfectly! I was so sure I'd tried exactly that code before posting here but heyhoh, I must have been doing something daft.
Again, thanks :slight_smile:
Sorry for necroing this thread, but which Sdfat library are you using? I keep running into errors with mine.
I imagine it was this version from August.
I also use that one, but the line
SdFat sd;
Keeps showing up as an error, along with several other lines when I copy and paste your sketch..
what error you are getting??
This is what I get when trying to compile the transmitter code:
In file included from sketch_oct18a.ino:4:
G:\Apps\Arduino\Sketches\libraries\SdFat/SdFat.h:294: error: conflicting return type specified for 'virtual void SdFile::write(uint8_t)'
G:\Apps\Arduino\hardware\arduino\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
sketch_oct18a:6: error: 'SdFat' does not name a type
sketch_oct18a.ino: In function 'void setup()':
sketch_oct18a:33: error: 'sd' was not declared in this scope
sketch_oct18a:33: error: 'SPI_HALF_SPEED' was not declared in this scope
sketch_oct18a:36: error: no matching function for call to 'SdFile::open(const char [9], int)'
G:\Apps\Arduino\Sketches\libraries\SdFat/SdFat.h:238: note: candidates are: uint8_t SdFile::open(SdFile&, uint16_t, uint8_t)
G:\Apps\Arduino\Sketches\libraries\SdFat/SdFat.h:239: note:                 uint8_t SdFile::open(SdFile&, char*, uint8_t)
G:\Apps\Arduino\Sketches\libraries\SdFat/SdFat.h:241: note:                 uint8_t SdFile::open(SdFile&, char*)
sketch_oct18a:37: error: 'sd' was not declared in this scope
this error message clearly telling you that Sdfat does not have any overloaded function whose 1st argument is of const char [9], type.
you can pass argument like uint8_t SdFile::open(SdFile&, uint16_t, uint8_t) or other related overloaded functions only.
send your full code ..
Hello and thanks for your replies.
My code is the exact same as the transmitter code posted above by Hooby.
hello!
i run your code and did not got any error.
so i suspect you might not added library properly.
goto http://arduino.cc/en/Guide/Libraries
if you still get the same error let us know.
BTW how you added library to transmitter code.?
I've tried to install the library on another PC with IDE 1.0.6 and it compiled correctly there.
I'll try the same on my own PC later this evening, I'll keep you posted.
OK, now I'm clueless. I've installed the library exactly as I did on my other PC and it doesn't compile.
I downloaded the 1.0.6 version and installed the library, no luck, it won't compile.
I'll copy the library files from the other PC tomorrow but I really have no idea what's happening.
Well, I got it figured out. De-installed Arduino, re-installed again and now the SDfat library works.
My older sketches will need an update as they relied on other FAT libaries but I'll manage.
Anyway, I'll try the transmitter and receiver code again later this afternoon, I expect it to work now.
After that, It's time to implement it into my current sketch.
Thanks for your help, most appreciated.
Ok, the transmission is received but not stored correctly when trying the first sketch.
I've tried swapping the SDcards but that didn't help. I ran sdformat on both cards and tried the example ReadWriteSdfat, that worked well.
Now, This is my code:
#include <SdFat.h>
const int receive_pin = 4;
const int Vpin = 2;
const int GND = 5;
SdFat sd;
SdFile myFile;
const int chipSelect = 10;
    sd.errorHalt("22opening rx.txt for write failed");  // If fails then error
        myFile.close();
But now I get the error:
error: opening rx.txt for write failed
This is the last error message in the sketch and I can't find out why. Do I need to close the file in void setup already?
Your IDE usually contains many libraries compatible with it. Use those if possible.
If you want to open it again in loop, you do.
