Getting wierd characters trough sda sca connection
hello, im trying to connect my hih8121 sensor to the arduino with this code and im getting very wierd characters in the serial monitor like squares , arrows etc...
Can someone help me out?
`/* includes */
#include <Wire.h>
/* prototypes */
void delay_minutes(unsigned int);
/* defines /
#define BYTES2READ (4)
#define HIH8121addr (0x27) /
slave I2c address /
#define EPOCH (1) /
time between reads (mins) */
Serial.begin(19200);
Wire.begin();
byte HIHdata[4]; // data read from the sensor
byte HIHstatus; // sensor status bits
unsigned int RHraw, Tempraw; // raw RH (%) and temp (c) values
float RH, TempC; // converted RH (%) and Temp (C)
byte dummydata = 0xff; // dummy data for kick write
unsigned int sample = 1; // sample counter
delay(3000); // wait while opening monitor screen
Serial.println(" HIH8121 Sensor Test");
// the following delay is just a reminder that on power up you want to
// wait before talking to the sensor so you can't put it into command mode
delay(50); // wait past the command window
/* print header /
Serial.println("Sample RH Temp (C)");
read sensor and display result loop*/
while (1) {
/* kick the sensor */
Wire.beginTransmission(HIH8121addr);
Wire.write(dummydata);
Wire.endTransmission(); // send it
delay(50); // 50 ms delay for measurement (~36.65 ms)
// get the data
Wire.requestFrom(HIH8121addr, BYTES2READ); // get 4 bytes of data
HIHdata[0] = Wire.read();
HIHdata[1] = Wire.read();
HIHdata[2] = Wire.read();
HIHdata[3] = Wire.read();
HIHstatus = HIHdata[0] & 0b11000000; // get status bits
if (HIHstatus != 0) {
Serial.println("Status Bits Error!");
HIHdata[0] = HIHdata[0] & 0b00111111; //mask status
Tempraw = (HIHdata[2] * 256) + HIHdata[3];
Tempraw = Tempraw / 4; //shift temperature
RHraw = (HIHdata[0] * 256) + HIHdata[1];
RH = ((float)RHraw / 16382.0) * 100.0;
TempC = (((float)Tempraw / 16382.0) * 165.0) - 40;
Serial.print(sample);
Serial.print(" ");
Serial.print(RH);
Serial.print(" ");
Serial.print(TempC);
delay_minutes(EPOCH);
sample++;
void delay_minutes(unsigned int mins) {
unsigned int count;
for (count = 0; count < mins; count++) {
delay(1000); // delay 60 seconds
//delay(1000); // use this if you want seconds epoch
void print_float(float f, int num_digits)
int f_int;
int pows_of_ten[4] = {1, 10, 100, 1000};
int multiplier, whole, fract, d, n;
multiplier = pows_of_ten[num_digits];
if (f < 0.0)
    f = -f;
    Serial.print("-");
whole = (int) f;
fract = (int) (multiplier * (f - (float)whole));
Serial.print(whole);
Serial.print(".");
for (n=num_digits-1; n>=0; n--) // print each digit with no leading zero suppression
     d = fract / pows_of_ten[n];
     Serial.print(d);
     fract = fract % pows_of_ten[n];
Yes. First lesson code tags.
`/* includes */
#include <Wire.h>
/* prototypes */
/* defines /
#define HIH8121addr (0x27) / slave I2c address /
#define EPOCH (1) / time between reads (mins) */
Learn how to use them then edit your post and include them.
Did you set your monitor to 19200?
amazing :smiley: it was just to change the monitor!
your the best
