Getting wrong characters in EEPROM.get
Good night everybody. I'm in need of a bit of help, thanks a lot in advance. I've this code that receives a string named ''valor'' via bluetooth, then writes it into the EEPROM memory in a charArray called "contrasena". The thing is that, for example, when I send "4039ED5C", what I get in the variable "contra", which stores in a string the data read from the EEPROM, is "⸮'⸮⸮⸮⸮?⸮⸮⸮?T@4039ED5C." I'm assuming there's a mistake in my handling of the address, but I don't know how to solve it. Thanks a lot!
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
#include <EEPROM.h>
String valor;
const char* aleatorio;
String alea = "2";
#define SERVICE_UUID        "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
class MyCallbacks: public BLECharacteristicCallbacks {
    void onWrite(BLECharacteristic *pCharacteristic) {
      std::string value = pCharacteristic->getValue();
      pCharacteristic->setValue(alea.c_str()); // Pone el numero aleatorio
      if (value.length() > 0) {
        valor = "";
        for (int i = 0; i < value.length(); i++) {
          // Serial.print(value[i]); // Presenta value.
          valor = valor + value[i];
        int longitud = 0;
        longitud = valor.length() + 1;
        char contrasena[longitud];
        valor.toCharArray(contrasena, longitud);
        EEPROM.put(0, contrasena[longitud]);
        EEPROM.commit();
        char cguardada[longitud];
        EEPROM.get(0, cguardada[longitud]);
        String contra = String(cguardada);
        Serial.println("*********");
        Serial.print("valor = ");
        Serial.println(valor); // Presenta valor.
        Serial.println(longitud);
        Serial.println(contrasena);
        Serial.println(cguardada);
  EEPROM.begin(512);
  BLEDevice::init("ESP32");
  BLEServer *pServer = BLEDevice::createServer();
  BLEService *pService = pServer->createService(SERVICE_UUID);
  BLECharacteristic *pCharacteristic = pService->createCharacteristic(
                                         CHARACTERISTIC_UUID,
                                         BLECharacteristic::PROPERTY_READ |
                                         BLECharacteristic::PROPERTY_WRITE
  pCharacteristic->setCallbacks(new MyCallbacks());
  pCharacteristic->setValue("Iniciado.");
  pService->start();
  BLEAdvertising *pAdvertising = pServer->getAdvertising();
  pAdvertising->start();
  delay(2000);
  //Serial.println("valor en el loop = ");
  //Serial.println(valor); // Presenta valor.
  aleatorio = "Contraseña modificada"; // Crea el numero aleatorio.
  alea = (String) aleatorio; // Lo convierte en String.
I think that this will work better
EEPROM.put(0, contrasena);
EEPROM.get(0, cguardada);
Already tried that, and it sends error on those lines saying that it doesn't fit the function EEPROM.get requirements. Any other ideas on what may actually be happening? Thanks for replying anyways :slight_smile:
I don't have an ESP or whatever you are using :wink: So I can't test. For the AVR, I get an error if I try
#include <EEPROM.h>
char txt[] = "4039ED5C";
  EEPROM.put(2, txt);
  int cnt = strlen(txt) + 1;
  char txt2[cnt];
  EEPROM.get(2, txt2);
  Serial.begin(57600);
  Serial.println(txt2);
Arduino: 1.8.5 (Windows 10), Board: "SparkFun RedBoard"
In file included from C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_214167\sketch_oct17a.ino:1:0:
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_214167\sketch_oct17a.ino: In function 'void setup()':
sketch_oct17a:12: error: no matching function for call to 'EEPROMClass::get(int, char [cnt])'
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_214167\sketch_oct17a.ino:12:21: note: candidate is:
C:\Users\sterretje\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\EEPROM\src/EEPROM.h:130:31: note: template<class T> T& EEPROMClass::get(int, T&)
     template< typename T > T &get( int idx, T &t ){
C:\Users\sterretje\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\EEPROM\src/EEPROM.h:130:31: note:   template argument deduction/substitution failed:
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_214167\sketch_oct17a.ino:12:21: note:   variable-sized array type 'char [cnt]' is not a valid template argument
I suggest that you test with fixed size arrays for your cguardada and contrasena and make the change that I sugegsted.
