GFORCE 100 Wiring Bluetooth Module
Hi, I got this code from Github but I couldn’t figure out how to wire my components to the Arduino. Please help
#include <Servo.h>
#include <gForceAdapter.h>
// Define USE_GFORCE to 1 to control hand using gForce.
// Define USE_GFORCE to 0 to show gestures one by one.
#define USE_GFORCE 1
#define gForceSerial Serial
#define thumb         0
#define indexfinger   1
#define middlefinger  2
#define ringfinger    3
#define littlefinger  4
#define armtwist      5
#define SERVOS_CNT    6
enum GestureType
  FistIdx = 0,
  ReleaseIdx,
  WaveInIdx,
  WaveOutIdx,
  TapIdx,
  ShootIdx,
  RelaxIdx,
  GestureCnt // Count
typedef struct
  int pos_min;
  int pos_max;
  int pos_offset;
} SERVO_POS_OFFSET;
const SERVO_POS_OFFSET SERVO_OFFSET[SERVOS_CNT] = {
    {5, 175, 0},
    {5, 175, 0},
    {5, 175, 0},
    {5, 175, 0},
    {5, 175, 0},
    {5, 175, 0}};
// Pos for thumb, finger, middle, ring, little, wrist
const int GESTURE[GestureCnt][SERVOS_CNT] = {
    {170, 170, 170, 170, 170,  90}, // fist
    { 10,  10,  10,  10,  10,  90}, // spread
    { 10,  10,  10,  10,  10, 170}, // wave in
    { 10,  10,  10,  10,  10,  10}, // wave out
    {170, 170,  10,  10,  10,  90}, // pinch
    { 10,  10, 170, 170, 170,  90}, // shoot
    { 40,  40,  40,  40,  40,  90}  // Relax
unsigned long SYS_GetTick(void);
int SYS_GetChar(unsigned char *data);
GForceAdapter gforce(SYS_GetChar, SYS_GetTick);
//unsigned long timeStamp;
Servo servos[SERVOS_CNT];
/* returns char count */
  int ret = gForceSerial.read();
  if (ret == -1)
    return 0;
  *data = (unsigned char)ret;
  return 1;
/* returns System time */
  return millis();
int servo_pos(GestureType gesture, int servo_id)
  int pos = GESTURE[gesture][servo_id];
  pos += SERVO_OFFSET[servo_id].pos_offset;
  pos = min(pos, SERVO_OFFSET[servo_id].pos_max);
  pos = max(pos, SERVO_OFFSET[servo_id].pos_min);
  return pos;
void perform_gesture(GestureType gestureIdx)
  static GestureType last_gesIdx = GestureCnt;
  Serial.print("Gesture ");
  Serial.print(gestureIdx);
  Serial.print(": ");
  if (last_gesIdx != gestureIdx)
    for (int i = 0; i < SERVOS_CNT; i++)
      int pos = servo_pos(gestureIdx, i);
      Serial.print(pos);
      Serial.print(",");
      servos[i].write(pos);
    last_gesIdx = gestureIdx;
  servos[0].attach(6);
  servos[1].attach(5);
  servos[2].attach(4);
  servos[3].attach(3);
  servos[4].attach(2);
  servos[5].attach(7);
  //  Serial.begin(115200);
  gForceSerial.begin(115200);
  //  timeStamp = millis();
  //put your main code here, to run repeatedly:
  //  if((millis() - timeStamp) > 5000)
#if USE_GFORCE
  GF_Data gForceData;
  if (OK == gforce.GetGForceData(&gForceData, 10))
    GF_Gesture gesture;
    switch (gForceData.type)
      case GF_Data::QUATERNION:
      case GF_Data::GESTURE:
        gesture = gForceData.value.gesture;
        if (gesture == GF_FIST)
          perform_gesture(FistIdx);
        else if (gesture == GF_SPREAD)
          perform_gesture(ReleaseIdx);
        else if (gesture == GF_WAVEIN)
          perform_gesture(WaveInIdx);
        else if (gesture == GF_WAVEOUT)
          perform_gesture(WaveOutIdx);
        else if (gesture == GF_PINCH)
          perform_gesture(TapIdx);
        else if (gesture == GF_SHOOT)
          perform_gesture(ShootIdx);
        else if (gesture == GF_RELEASE)
          perform_gesture(RelaxIdx);
        else if (gesture == GF_UNKNOWN)
      default:
#else
  static int i = 0;
  perform_gesture(i);
  delay(2000);
  if (++i >= GestureCnt)
    i = 0;
#endif
What are Your "components" that needs to be wired? Links, wirings, data.....
Just uploaded the picture of the bluetooth module. I need to wire it to my arduino Uno. To read the data
Sorry but Your pictures are of no help. Come back when You've got more facts.
