Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Which analog pin are you using A5?
If so;
int probePin = 5;
Should be;
int probePin = A5;
Then connect pin A5 to gnd then 5V, see if your get min and max readings.
Use a potentiometer to check your input as you may not have a calibrated ghost nearby.
Thanks.. Tom... ![]()
