Gibberish at end of Serial Monitor
Hi Everyone,
This is more a question of curiosity than anything.
I have a simple timer program which runs fine. It activates different relays at different times during the program.
The program is working fine.
I have used the Serial.println(); command throughout the program just so I can see where it is up to.
The last few Serial.println() lines displayed show gibberish. Just random charactors and I am wondering why.
The countdown is triggered by a button press and every time the button is pressed it starts fine and display the my messages in the serial monitor but always the last few lines show gibberish.
Can anyone see why? Is it something I have done?
It doesn't seem to effect the program at all, just what is displayed in the serial monitor.
Serial Monitor Read Out
Uneek LEDs 30min Arena Light Timer with 5min warning.
Uses lights 2.4gHz Remote system
Button pressed!
Lights On Signal
Button Press Complete... Entering 30min Timer
Timer at 10min
Timer at 20min
Timer at 25min.. 5m Indicator Light On
Timer at 30min
End of Timer
Turn all Relays off and wait for next keypress
Lights Off Signal
End oæ�Q¥µ•É5)"Õɹ�…±±�I•±…åÍ�½™™�…¹‘�Ý…¥Ñ�™½É�¹•áÑ�­•åÁÉ•ÍÍ5)þButton pressed!
Lights On Signal
Timer at 10min
Timer at 20min
Timer at 30min
End of Timer
Lights Off Signal
End o
#include <LowPower.h>
#define SERIAL_BAUD   115200
#define LED           9 // Moteinos have LEDs on D9
#define BUTTON_INT    1 //user button on interrupt 1 (D3)
#define BUTTON_PIN    3 //user button on interrupt 1 (D3)
#define LightsOn        8 //Turn Lights ON
#define LightsOff       6 //Output Pin for Lights Off
#define Strobelight     7 //Relay Output to activate Strobe light to indicate 5 min left
//RFM69 radio;
  Serial.begin(SERIAL_BAUD);
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  pinMode(LED, OUTPUT);
  attachInterrupt(BUTTON_INT, handleButton, FALLING);
  pinMode(LightsOn, OUTPUT);
  pinMode(LightsOff, OUTPUT);
  pinMode(Strobelight, OUTPUT);
  // initialize digital pin 4 as an Output to drive the relay to control Turn the Flood Lights on/off
  digitalWrite(LightsOff, LOW);
  digitalWrite(LightsOff, HIGH);
  delay(500);                                             //Simulate Keypress
  delay(2000);
  digitalWrite(Strobelight, LOW);
  digitalWrite(LightsOn, LOW);
  Serial.println("Uneek LEDs 30min Arena Light Timer with 5min warning.");
  Serial.println("Uses lights 2.4gHz Remote system");
//******** THIS IS INTERRUPT BASED DEBOUNCING FOR BUTTON ATTACHED TO D3 (INTERRUPT 1)
#define FLAG_INTERRUPT 0x01
volatile int mainEventFlags = 0;
boolean buttonPressed = false;
void handleButton()
  mainEventFlags |= FLAG_INTERRUPT;
byte LEDSTATE = LOW; //LOW=0
  if (mainEventFlags & FLAG_INTERRUPT)
    LowPower.powerDown(SLEEP_120MS, ADC_OFF, BOD_ON);
    mainEventFlags &= ~FLAG_INTERRUPT;
    if (!digitalRead(BUTTON_PIN)) {
      buttonPressed = true;
  if (buttonPressed)
    delay(1000);                           //button debounce
    Serial.println("Button pressed!");
    if (LEDSTATE == LOW)
      LEDSTATE = HIGH;
      digitalWrite(LED, LEDSTATE);
      digitalWrite(LightsOn, HIGH);
      Serial.println("Lights On Signal");
      delay(500);                                             // Wait 0.5 Sec and then Turn off Relay.  Simulates a button press
      //digitalWrite(LED, LOW);
      Serial.println("Button Press Complete... Entering 30min Timer");
      //Start 30min Timer
      //     delay(10L * 60L * 1000L);                               //Timer at 10min
      delay(100000);
      Serial.println("Timer at 10min");
      //    delay(10L * 60L * 1000L);                               //Timer at 20min
      delay(100000);
      Serial.println("Timer at 20min");
      //  delay(300L * 1000L);                                    //Timer at 25min
      delay(100000);
      digitalWrite(Strobelight, HIGH);                      // Turn 5min Warning Light on to warn riders the lights will turn off in 5 minutes
      Serial.println("Timer at 25min.. 5m Indicator Light On");
      //    delay(300L * 1000L);                                    //5min delay
      delay(100000);
      Serial.println("Timer at 30min");
      Serial.println("End of Timer");
      Serial.println("Turn all Relays off and wait for next keypress");
      Serial.println("Lights Off Signal");
      //  Serial.println("Timer at 30min");
      LEDSTATE = LOW;
Try to replace the LowPower delay in the button press block with a regular delay and see what happens. Try to use the default baud rate of 9600 and make sure that the correct baud rate is selected in the terminal.
Thanks @Danois90 appreciate the quick response.
I have used different variations of the same code for a long time and haven't seen it happen before.
Which LowPower delay are you referring to?
This one: "LowPower.powerDown(SLEEP_120MS, ADC_OFF, BOD_ON);" - replace it with "delay(120)" or remove it entirely, I cannot see the purpose of it.
Hi @Danois90, I changed the baud rate with no change so removed the low power delay and added a normal one.
That has fixed it. The serial monitor now reads correctly again.
The Low Power delay is supposed to go to a LowPower library and act as a power saving feature.
I have stripped the code back somewhat so you are right that it really doesnt do a lot in this program... except make the serial monitor go a little crazy.
Thanks for you responses. Its much appreciated.
You have delays of 10 minutes wasting energy and you are concerned about the 250ms delay? Giggle.. ;o)
