Hi, I'm trying to use both DACs on the arduino Giga but whenever I try to start dac1 the program seems to get stuck. I am then also unable to upload any new sketches to the arduino unless I use the bootloader(double tapping the reset button). I've tried using only one dac, but the issue happens whenever I try to use the DAC on A13. Could there be some conflict with the giga display, lvgl or I2C?
#include "Arduino_H7_Video.h"
#include "Arduino_GigaDisplayTouch.h"
#include <Arduino_GigaDisplay.h>
#include "lvgl.h"
#include "ui.h"
#include <Wire.h>
#include <TEA5767Radio.h>
#include <Arduino_AdvancedAnalog.h>
AdvancedADC adc(A0);
AdvancedDAC dac0(A12);
AdvancedDAC dac1(A13);
uint64_t last_millis = 0;
TEA5767Radio radio = TEA5767Radio();
/* Insert resolution WxH according to your SquareLine studio project settings */
Arduino_H7_Video Display(480, 800, GigaDisplayShield);
Arduino_GigaDisplayTouch Touch;
GigaDisplayBacklight backlight;
float volume = 0.30;
void event_FreqSlider(lv_event_t * e)
float value;
lv_obj_t * FreqSlider = lv_event_get_target_obj(e);
/*Refresh the text*/
value = float(lv_slider_get_value(ui_FreqSlider));
value = value/10;
Serial.print(value);
char str[32];
sprintf(str, "%.1f", value);
radio.setFrequency(value);
lv_label_set_text(ui_Freq, str);
//lv_obj_align_to(ui_Freq, ui_FreqSlider, LV_ALIGN_OUT_TOP_MID, 0, -15); /*Align top of the slider*/
delay(3000);
Display.begin();
backlight.begin();
Touch.begin();
Wire.begin();
radio.setFrequency(102.1);
backlight.set(70);
ui_init();
lv_obj_add_event_cb(ui_FreqSlider, event_FreqSlider, LV_EVENT_VALUE_CHANGED, NULL);
// Resolution, sample rate, number of samples per channel, queue depth.
if (!adc.begin(AN_RESOLUTION_12, 16000, 32, 128)) {
Serial.println("Failed to start analog acquisition!");
while (1);
while (!Serial) {
if (!dac0.begin(AN_RESOLUTION_12, 16000, 32, 128)) {
Serial.println("Failed to start DAC0 !");
while (1);
if (!dac1.begin(AN_RESOLUTION_12, 16000, 32, 128)) {
Serial.println("Failed to start DAC1 !");
while (1);
The loop portion of the code isn't included, as dac1 isn't used there yet
