I compiled the example GagaCameraDisplay and uploaded to the Giga with no problems.
I would like to overlay text in the frame buffer.
Is there library to put text inside the frame buffer? What is the best way to do this?
I tried to use the ArduinoGraphics library but crashed the Giga. Seems the dsi and ArduinoGraphics don't play well together.
#include "arducam_dvp.h"
#include "Arduino_H7_Video.h"
#include "dsi.h"
#include "SDRAM.h"
// This example only works with Greyscale cameras (due to the palette + resize&rotate algo)
#define ARDUCAM_CAMERA_HM01B0
#ifdef ARDUCAM_CAMERA_HM01B0
#include "Himax_HM01B0/himax.h"
HM01B0 himax;
Camera cam(himax);
#define IMAGE_MODE CAMERA_GRAYSCALE
#elif defined(ARDUCAM_CAMERA_HM0360)
#include "Himax_HM0360/hm0360.h"
HM0360 himax;
Camera cam(himax);
#elif defined(ARDUCAM_CAMERA_OV767X)
#include "OV7670/ov767x.h"
// OV7670 ov767x;
OV7675 ov767x;
Camera cam(ov767x);
#define IMAGE_MODE CAMERA_RGB565
#elif defined(ARDUCAM_CAMERA_GC2145)
#include "GC2145/gc2145.h"
GC2145 galaxyCore;
Camera cam(galaxyCore);
#endif
// The buffer used to capture the frame
FrameBuffer fb;
// The buffer used to rotate and resize the frame
FrameBuffer outfb;
Arduino_H7_Video Display(800, 480, GigaDisplayShield);
void blinkLED(uint32_t count = 0xFFFFFFFF)
pinMode(LED_BUILTIN, OUTPUT);
while (count--) {
digitalWrite(LED_BUILTIN, LOW); // turn the LED on (HIGH is the voltage level)
delay(50); // wait for a second
digitalWrite(LED_BUILTIN, HIGH); // turn the LED off by making the voltage LOW
uint32_t palette[256];
// Init the cam QVGA, 30FPS
if (!cam.begin(CAMERA_R320x240, IMAGE_MODE, 30)) {
blinkLED();
// Setup the palette to convert 8 bit greyscale to 32bit greyscale
for (int i = 0; i < 256; i++) {
palette[i] = 0xFF000000 | (i << 16) | (i << 8) | i;
Display.begin();
if (IMAGE_MODE == CAMERA_GRAYSCALE) {
dsi_configueCLUT((uint32_t*)palette);
outfb.setBuffer((uint8_t*)SDRAM.malloc(1024 * 1024));
// clear the display (gives a nice black background)
dsi_lcdClear(0);
dsi_drawCurrentFrameBuffer();
dsi_lcdClear(0);
#define HTONS(x) (((x >> 8) & 0x00FF) | ((x << 8) & 0xFF00))
// Grab frame and write to another framebuffer
if (cam.grabFrame(fb, 3000) == 0) {
// double the resolution and transpose (rotate by 90 degrees) in the same step
// this only works if the camera feed is 320x240 and the area where we want to display is 640x480
for (int i = 0; i < 320; i++) {
for (int j = 0; j < 240; j++) {
((uint8_t*)outfb.getBuffer())[j * 2 + (i * 2) * 480] = ((uint8_t*)fb.getBuffer())[i + j * 320];
((uint8_t*)outfb.getBuffer())[j * 2 + (i * 2) * 480 + 1] = ((uint8_t*)fb.getBuffer())[i + j * 320];
((uint8_t*)outfb.getBuffer())[j * 2 + (i * 2 + 1) * 480] = ((uint8_t*)fb.getBuffer())[i + j * 320];
((uint8_t*)outfb.getBuffer())[j * 2 + (i * 2 + 1) * 480 + 1] = ((uint8_t*)fb.getBuffer())[i + j * 320];
((uint16_t*)outfb.getBuffer())[j * 2 + (i * 2) * 480] = HTONS(((uint16_t*)fb.getBuffer())[i + j * 320]);
((uint16_t*)outfb.getBuffer())[j * 2 + (i * 2) * 480 + 1] = HTONS(((uint16_t*)fb.getBuffer())[i + j * 320]);
((uint16_t*)outfb.getBuffer())[j * 2 + (i * 2 + 1) * 480] = HTONS(((uint16_t*)fb.getBuffer())[i + j * 320]);
((uint16_t*)outfb.getBuffer())[j * 2 + (i * 2 + 1) * 480 + 1] = HTONS(((uint16_t*)fb.getBuffer())[i + j * 320]);
dsi_lcdDrawImage((void*)outfb.getBuffer(), (void*)dsi_getCurrentFrameBuffer(), 480, 640, IMAGE_MODE == CAMERA_GRAYSCALE ? DMA2D_INPUT_L8 : DMA2D_INPUT_RGB565);
blinkLED(20);
