Giga Display Shield SLS not working
Hi all,
trying everything but I got the same error every change I do. When I upload the sketch, the display is completely pixelated as immage pinned.
What I'm doing wrong?
If i comment everything except the lvgl code the display works fine, so it's a problem with my code for sure.
#include "Arduino_H7_Video.h"
#include "Arduino_GigaDisplayTouch.h"
#include "lvgl.h"
#include "ui.h"
#include <ArduinoJson.h>
#include "Communications.h"
#include "Index.h"
#include "FlipDot7Segments.h"
WiFiSSLClient clientSSL;
const int MAX_RETRY = 3;
String ssid_string;
String pass_string;
char ssid[50];
char pass[50];
/* Insert resolution WxH according to your SquareLine studio project settings */
Arduino_H7_Video          Display(800, 480, GigaDisplayShield);
Arduino_GigaDisplayTouch  Touch;
unsigned long previousMillis = 0;
unsigned long currentMillis = 0; // Aggiungi questa linea
const long interval = 1000;
const long interval2 = 5000;
  Display.begin();
  Touch.begin();
  ui_init();
  Serial.println("Application Started");
  Serial1.begin(9600);
  ssid_string = String(lv_textarea_get_text(ui_SSID));
  pass_string = String(lv_textarea_get_text(ui_PASS));
  ssid_string.toCharArray(ssid, ssid_string.length() + 1);
  pass_string.toCharArray(pass, pass_string.length() + 1);
  connectToWiFi(ssid, pass);
  printWifiStatus();
  previousMillis = millis();
  /* Feed LVGL engine */
  lv_timer_handler();
  delay(5);
  if (clientSSL.available()) {
    StartIndexRequest(&clientSSL);
    if(currentMillis - previousMillis >= interval) {
      String data = "";
      unsigned long startTime = millis();
      do {
        data = read_response(&clientSSL);
      } while (data == "" && (millis() - startTime) < 10000);
      if ((millis() - startTime) < 10000) {
        if (data != "") {
          String json = get_json(data);
          String index = get_index(json);
          Serial.println("DATA:\n" + json + "\n----------------- END JSON");
          Serial.println("INDEX:" + index + "\n----------------- END INDEX");
          visualize(index.toInt());
        Serial.println("----------------- START DELAY 5000");
        while(millis() - previousMillis < interval2) {
          // do nothing
        Serial.println("----------------- END DELAY");
        Serial.println("TIMEOUT:" + (String)(millis() - startTime));
        clientSSL.stop();
  if (WiFi.status() != WL_CONNECTED)
  if (!clientSSL.connected())
    connectToServer();
void connectToServer() {
  if (!clientSSL.connected()) {
    int retries = 0;
    while (!clientSSL.connect(HOST_NAME, 443) && retries++ < MAX_RETRY) {
        Serial.println("Connecting to server: " + (String)HOST_NAME);
      Serial.println("Connected to server: " + (String)HOST_NAME);
    else {
      Serial.println("Not connected to server: " + (String)HOST_NAME);
      WiFi.disconnect();
