Is there a possibility to use the Giga Display Shield with the UNO R4 WiFi?
If so how?
Any limitations compared to the GIGA WiFi R1?
I like the 5V ADC, and I will mount the 2 separately any way
Fort a fast and reliable answer, please post a link to the datasheet for the display.
Datasheets usually contain useful application notes.
Even using a Giga WiFi R1 I would not mount the display to the connector, so UNO and Giga would require wiring. So the 5V ADC and logic pins from the UNO (and price) would be my choice if compatible.
Thanks!
That device uses 3.3 volt logic signals, not suitable for an UNO that uses 5 volt signal logic signals. Level shifters are needed.
I don't know the Giga WiFi R1 at all.....
Mounting to a connector..... What is the problem there?
You aim for a quite advanced setup, beyond my experience. More information will surely trigger more knowing helpers.
What's Your goal, what's this setup supposed to be used for?
Plating industry
Thanks but... Could You please read and reply to the entire reply #4?
Status information and control of heaters, agitation, Ph, amps, etc, etc of baths, rectifiers,
Arduino in a ip67 box, display in the front
