I need to read information from a Fronius Smart Metter TS100A-1.
For this , I used ModbusRtu.h library and module RS485 max connected to Mega 2560
The sample from library function very well.
When I changed Mega 2560 with Giga R1, communication didn't function.
Do you know what library can be used for Giga R1?
#include <ModbusRtu.h>
// data array for modbus network sharing
uint16_t au16data[1];
uint8_t u8state;
Modbus object declaration
u8id : node id = 0 for master, = 1..247 for slave
u8serno : serial port (use 0 for Serial)
u8txenpin : 0 for RS-232 and USB-FTDI
or any pin number > 1 for RS-485
Modbus master(0, Serial2,12);
This is an structe which contains a query to an slave device
modbus_t telegram;
unsigned long u32wait;
master.begin( 9600 ); // baud-rate at 9600
master.setTimeOut( 2000 ); // if there is no answer in 2000 ms, roll over
u32wait = millis() + 1000;
u8state = 0;
switch( u8state ) {
case 0:
if (millis() > u32wait) u8state++; // wait state
case 1:
telegram.u8id = 1; // slave address
telegram.u8fct = 3; // function code (this one is registers read)
telegram.u16RegAdd = 4; // start address in slave
telegram.u16CoilsNo = 1; // number of elements (coils or registers) to read
telegram.au16reg = au16data; // pointer to a memory array in the Arduino
master.query( telegram ); // send query (only once)
u8state++;
case 2:
master.poll(); // check incoming messages
if (master.getState() == COM_IDLE) {
u8state = 0;
u32wait = millis() + 100;
Serial.println(au16data[0]);
