Giga R1 Wifi bootloader crashes while using 1-wire chip
I am trying to read the contents of a DS2431 1-wire chip using the Giga R1 Wifi board, the OneWire library, and the DS2431 library. It can pull the serial number of the chip, but once it gets to the read operation it immediately crashes and goes into the error state (red LED next to boot0 button blinks 4 times slow and 4 times fast). Resetting the code does nothing, reuploading does nothing, I'm really not sure what's wrong with it. I've posted the example code below. This is unaltered example code from the DS2431 library. There are two read functions in the library, one for single bytes and one for multiple bytes. Both cause the board to crash. I ran this same sketch on the Uno R4 Wifi and it works fine. I'm still new to 1-wire devices, so any help is greatly appreciated.
DS2431 example that dumps the whole memory and prints it to Serial.
Then a write operation is done and the memory is read again.
MIT License
Copyright (c) 2017 Tom Magnier
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
#include <DS2431.h>
#include <OneWire.h>
const int ONE_WIRE_PIN = 9; // One Wire pin, change according to your needs. A 4.7k pull up resistor is needed.
OneWire oneWire(ONE_WIRE_PIN);
DS2431 eeprom(oneWire);
  while (!Serial); // wait for Serial to come up on USB boards
  // Search the 1-Wire bus for a connected device.
  byte serialNb[8];
  oneWire.target_search(DS2431::ONE_WIRE_FAMILY_CODE);
  if (!oneWire.search(serialNb))
    Serial.println("No DS2431 found on the 1-Wire bus.");
    return;
  // Check serial number CRC
  if (oneWire.crc8(serialNb, 7) != serialNb[7])
    Serial.println("A DS2431 was found but the serial number CRC is invalid.");
    return;
  Serial.print("DS2431 found with serial number : ");
  printBuffer(serialNb, 8);
  Serial.println("");
  // Initialize DS2431 object
  eeprom.begin(serialNb);
  // Read all memory content
  byte data[128];
  eeprom.read(0, data, sizeof(data));
  Serial.println("Memory contents : ");
  printLargeBuffer(data, sizeof(data));
  Serial.println("");
  // Write a 8-byte row
  byte newData[] = {1,2,3,4,5,6,7,8};
  word address = 0;
  if (eeprom.write(address, newData, sizeof(newData)))
    Serial.print("Successfully wrote new data @ address ");
    Serial.println(address);
    Serial.print("Failed to write data @ address ");
  Serial.println("");
  // Read again memory content
  Serial.println("");
  // Read single byte
  Serial.print("Data @ address ");
  Serial.print(address);
  Serial.print(" : ");
  Serial.println(eeprom.read(address));
  // Nothing to do
void printBuffer(const uint8_t *buf, uint8_t len)
  for (int i = 0; i < len-1; i++)
    Serial.print(buf[i], HEX);
    Serial.print(",");
  Serial.println(buf[len-1], HEX);
void printLargeBuffer(const uint8_t *buf, uint16_t len)
  uint8_t bytesPerLine = 8;
  for (int i = 0; i < len / bytesPerLine; i++)
    Serial.print(i * bytesPerLine);
    Serial.print("\t\t:");
    printBuffer(buf + i * bytesPerLine, bytesPerLine);
Hi Brazien,
I was having a very similar issue as you with a onewire DS18B20. I tried a few libraries which all had the same issue. However MicroDS18b20 by Alex Gyver worked flawlessly with the Giga R1. Perhaps by comparing the libraries you may find your solution but unfortunately I am still very new to this so cant be more help.
James
James,
Thank you for your input! I'll definitely take a look at the MicroDS18b20 library and see what the difference is. One step closer to finding the solution.
Cheers,
Brazien
