Hello there, I am attempting to communicate with UDP via WiFi, from my laptop to my Giga R1.
With the below code I can connect to WiFi and successfully send and receive a packet using packet sender on the laptop. However this is only when the Giga is connect via USB to a port in the laptop. I have an external power supply for the Giga and I want to be able to receive packets without having to be connected to the laptop. Any help is appreciated.
#include <SPI.h>
#include <WiFi.h>
#include <WiFiUdp.h>
int status = WL_IDLE_STATUS;
//#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = "SSID"; // your network SSID (name)
char pass[] = "Password"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key index number (needed only for WEP)
unsigned int localPort = 4210; // local port to listen on
char PacketBuffer[250]; //buffer to hold incoming packet
WiFiUDP Udp; //Creates a named instance of the WiFi UDP class that can send and receive UDP messages
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true)
// attempt to connect to WiFi network:
while (status != WL_CONNECTED)
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 5 seconds for connection:
delay(5000);
Serial.println("Connected to WiFi");
printWifiStatus();
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
Udp.begin(localPort);
// if there's data available, read a packet
int packetSize = Udp.parsePacket();
if (packetSize)
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remoteIp = Udp.remoteIP();
Serial.print(remoteIp);
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into packetBufffer
int len = Udp.read(PacketBuffer, 200);
PacketBuffer[len] = 0;
Serial.println("Contents:");
Serial.println(PacketBuffer);
