[GITHUB] ARDUINO-SENSORS - Generic and Reliable Sensors Library
Hi folks!
Here is the library that I made to use with my robots, that includes a bunch of sensors for all kind of stuffs.
It's the ArduinoSensors (https://github.com/ivanseidel/ArduinoSensors) and it's available at GitHub.
All the sensors are implemented using the ArduinoThread (https://github.com/ivanseidel/ArduinoThread) concept, and ready to work with almost every micro-controller.
Included Classes:
  • AnalogIn Class
  • AnalogVoltage Class
  • MLX90614 Temperature Sensor
  • HMC6352 Compass sensor
  • EZ Ultrasonic Sensor
  • Ping Ultrasonic Sensor
  • HC-SR04 Ultrasonic Sensor
  • InvenSense IMU MPU9150
  • InvenSense IMU MPU6050
  • Sharp Infrared Short Distance Sensor (GP2D120XJ00F)
  • Sharp Infrared Medium Distance Sensor (GP2Y0A21YK)
  • Sharp Infrared Long Distance Sensor (GP2Y0A02YK0F)
Included Interfaces:
  • TemperatureInterface
  • DistanceInterface
  • VoltageInterface
  • AngleInterface
This library of libraries was made to target many others sensors, with it's generic Interfaces.
I'm still documenting, but that's going to take time. If there is anyone interested in doing that, I appreciate the help!
Also, take a look at my others libraries, they might help: Arduino Thread | https://github.com/ivanseidel/ArduinoThread LinkedList | https://github.com/ivanseidel/LinkedList Due Timer | https://github.com/ivanseidel/DueTimer Arduino Gaussian | https://github.com/ivanseidel/Gaussian Arduino User Interface | https://github.com/ivanseidel/ArdUI
Interesting links, bookmarked
BTW. I think that one link to your github repo in your signature will be enough
robtillaart: Interesting links, bookmarked
Thanks! Comments are welcome =)
Changed it to a few ones...
---------- NEW CLASS ---------- A new concept for Analog input pins: AnalogVoltage.
Whit this object, you can easily port almost every Analog sensor that requires a reliable Reference Voltage to work.
Let's say the Sharp sensor: It outputs up to 3.1V. It works on both 3.3V and 5V plataforms, but... You would need a library for each of them, since the default reference is different.
With this class, it knows the default AREF voltage of the Arduino, and can perfecly fit in both 5v and 3.3v without a line more of code...
interesting thought to make it voltage independant!
some remarks:
static const long cachedMaxValue = 1023; probably int works well enough saves 2 bytes
float percentage = (((float) ADValue) / cachedMaxValue); could be float percentage = ( ADValue * (1.0/cachedMaxValue); // will become a compile time calculated value which is faster @ runtime + no casting need.
rewrote function as I think there is a bug if only v2 was NO_VOLTAGE, please check
AnalogVoltage(int _inPin = -1, float minV = NO_VOLTAGE, float maxV = NO_VOLTAGE): AnalogIn(_inPin)
  voltage = 0;
  minVoltage = (minV == NO_VOLTAGE) ? 0.0 : minV;
  maxVoltage = (maxV == NO_VOLTAGE) ? defaultAnalogReference : maxV;
Think you can save some bytes more if you use integers representing milliVolts for the voltages, also the math will be faster.
robtillaart: static const long cachedMaxValue = 1023; probably int works well enough saves 2 bytes
  voltage = 0;
Will be added in the next version! Thanks!
Thanks for the library. It saved me a lot of work and it looks nice with the threading but I'm having some trouble using it.
I looked at an example and did the same but for a SharpShort sensor. When I tried to compile it, I always got an error saying undefined reference to vtable in SharpInterface. To resolve that error, I had to make the function convertDistance a pure virtual (virtual float convertDistance(float value) = 0;)
Maybe something you could add...
Jasper
japus: Hi,
Jasper
Thanks for the notice! I'm still coding some parts, and thinking about anothers... I think that next month the library will be more complete, but please, use and give me feedback, so that I can know what to improve.
Thanks, Ivan
