Im currently longing to implement a rather simple task into my Arduino uno.
void setup(){
float Freqs[] = {5, 4, 3, 2, 1, 2, 3, 4, 5};
float Freq = 3.4 // Average frequency of the above
float T = 0.29 // Average Period (1/freqs)
pinMode(3, OUTPUT);
pinMode(A0, INPUT);
pinMode(A2, INPUT);
int POS1 = digitalread(A2); // read analog pin A2 as digital and set it to a variable
int POS2 = digitalread(A0);
unsigned long lastUpdate
int i;
for (i = 0; i < 18) {
float pwm = (255*freqs[i])/5
float Tpwm = ((1/Freq)*(Freq/Freq[i])
if(POS1 == HIGH) // time to start
lastUpdate = millis();
analogWrite(3, pwm)
if((millis() - lastUpdate) > Tpwm) // time to update
analogWrite(3, pwm);
i=i+1; }
if else((POS2 == HIGH) || ((millis() - lastUpdate) > T))
int j;
for (j = 0; j < 18) {
float pwm2 = (255*freqs[j])/5
float Tpwm2 = (1/Freq)*(Freq/Freq[j])
analogWrite(3, pwm2)
if((millis() - lastUpdate) > Tpwm2)
{lastUpdate = millis();
analogWrite(3, pwm2);
j=j+1;}
if j == 17{ { while(1) { }; } // end programm.
Ill run you trough; First we set Variables, Inputs, and Outputs. Then we have pwm and Tpwm, which correspond to a certain Voltage for a relative Time.
Now what id like to see happen. Proggramm starts; It cycles trough all Voltages (pwm), waiting for a time (Tpwm), all corresponding to Freqs (i) from the above. Then when Finished time T is over or POS-ition 2 is reached it will do the Same thing once more.
The End.
can you take a short inspection and maybe give a critique for the Programming?
Function 'digitalread' could not be resolved ATest.ino /ATest line 8 Semantic Error
../ATest.ino: In function 'void setup()':
../ATest.ino:4:1: error: expected ',' or ';' before 'float'
../ATest.ino:11:1: error: expected initializer before '}' token
../ATest.ino:2:7: warning: unused variable 'Freqs' [-Wunused-variable]
../ATest.ino:3:7: warning: unused variable 'Freq' [-Wunused-variable]
../ATest.ino:8:5: warning: unused variable 'POS1' [-Wunused-variable]
int POS1 = digitalRead(A2); // read analog pin A2 as digital and set it to a variable
../ATest.ino:9:5: warning: unused variable 'POS2' [-Wunused-variable]
int POS2 = digitalRead(A0);
../ATest.ino: In function 'void loop()':
../ATest.ino:16:19: error: expected ';' before ')' token
../ATest.ino:17:18: error: 'freqs' was not declared in this scope
float pwm = (255*freqs)/5
../ATest.ino:19:3: error: expected ',' or ';' before '}' token
../ATest.ino:17:7: warning: unused variable 'pwm' [-Wunused-variable]
../ATest.ino:20:6: error: 'POS1' was not declared in this scope
../ATest.ino:22:1: error: 'lastUpdate' was not declared in this scope
../ATest.ino:23:16: error: 'pwm' was not declared in this scope
analogWrite(3, pwm)
../ATest.ino:31:10: error: expected '(' before 'else'
../ATest.ino:45:30: error: expected '}' at end of input
pinMode(3, OUTPUT);
pinMode(A0, INPUT);
pinMode(A2, INPUT);
int i;
for (i = 0; i < 10) {
float pwm = (255 * freqs[i]) / 5
float Tpwm = ((1 / Freq) * (Freq / Freq[i])
if (POS1 == HIGH) // time to start
analogWrite(3, pwm)
if ((millis() - lastUpdate) > Tpwm) // time to update
i = i + 1;
int j;
for (j = 0; j < 10) {
float pwm2 = (255 * freqs[j]) / 5
float Tpwm2 = (1 / Freq) * (Freq / Freqs[j])
if ((millis() - lastUpdate) > Tpwm2)
{ lastUpdate = millis();
j = j + 1;
if j == 17{ { while
Edited and formatted.
Indeed I have not yet tested if it does what I want it to do. I will find myself an Oscilloscope and watch it.
bW,
David
ps. maybe you can tell wether or not I have used the for function correctly. I want pwm and Tpwm to change accordingly to ( i ), then it should change when its time has come.
int i;
analogWrite(3, pwm)
i = i + 1;
Here I am dragging this old thread to daylight again. I hace since rewritten the Sketch, thereby shortening it, an have tested and pushed it over and over. This is the up to date sketch:
float Freqs[] = {0.4, 0.3, 0.2, 2, 3, 4}; // Voltage/Frequency Value Array
float DFreq = 2.2; //Average of above
float AFreq = 11; // Sum of Above
float T = (1000 / 2.2); //Making of Period and converting to millis (multiply 1000)
unsigned long lastUpdate;
unsigned long START;
int i;
float pwm = (255 * Freqs[i] / 5);
float Tpwm = (T * Freqs[i] / AFreq);
pinMode(9, OUTPUT);
if (millis() == 5000) { // time to start
START = millis();
for (i = 0; i < 6; i = i + 1) {
analogWrite(9, pwm);
if ((millis() - lastUpdate) >= Tpwm) { // time to update
i = i + 1;
if ((millis() - START) == T) { // Repeat after one Period
i = 0;}
Soo, what I want it to do is this: put pwm on Pin 9, then when the time has come put updated pwm's on pin 9. Until the full Period is over, at this point it should restart.
What it does is the Following. It stays Quiet for the first 5000ms (as coded in the first loop-line), then it will output the first pwm (i), then stay there, forever!
My own critic would be the placement of the if sentences, should I put them infront or after analog write.
It seems as soon as little arduino starts his analogwriting he is busy until I put him out of comission again.
On the other hand there might be an easier way to do it, without using the for loop altogether?
The variable Tpwm should be unsigned long as that is what millis() returns.
The variable pwm should be byte as analogWrite() takes a value from 0 to 255
In general you should avoid float variables on an Arduino as floating point maths is very slow. Most things can be done with integer maths after a little thought.
I have no idea what this is meant to do
i = 0;}
and, in any case the variable T should be unsigned long.
This will run exactly one time five seconds after power on (and only if it doesn't miss the 5000 mark - won't happen in this situation as you're not doing anything else).
If you want it to wait 5 seconds to start up, set a delay(5000) in your setup().
