giving a char* an address gets me "does not name a type"
Isn't this the proper way to init a pointer?
char *event[6];
int e = 6;
event = &e;
It errors out on 'event' does not name a type
One of the correct variants is
int *event;
int e = 6;
event = &e;
But what exactly you are trying to achieve?
alesam: One of the correct variants is
int *event;
int e = 6;
event = &e;
difficult to guess without a code.
char *event[6]; declares an array of pointers, perfectly legal. Is that what you want?
Later you can use this to store the addresses of characters → event[2] = &some_char_variable;
In your example, if you want event (which is undefined) to hold the address of e, you either need to declare event as a pointer ( char *event = &e;) or use one of your array positions (event[0] = &e;).
Note that using the same identifier for each of these in the same code space is not permitted.
mattlogue: Isn't this the proper way to init a pointer?
char *event[6];
int e = 6;
event = &e;
iowevent[1] = &e; would be legal. You are trying to assign a value to a variable which has not been previously declared.
char *event[6];
int e = 6;
event = &e;
That is not the error my compiler shows.
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\XXXX\AppData\Local\Temp\arduino_modified_sketch_125381\sketch_apr09a.ino: In function 'void setup()':
sketch_apr09a:7:7: error: incompatible types in assignment of 'int*' to 'char* [6]'
 event = &e;
exit status 1
option enabled in File -> Preferences.
This error message tells you exactly what's wrong.
