Giving an Error when adding firebase library and AHT10 library together ESP32
I wrote a code to get the temperature and send the data to the firebase DB using ESP32
but there is an error when adding the AHTX0 library to the code.
This is the error.
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400e7fcf PS : 0x00060f30 A0 : 0x800e7f16 A1 : 0x3ffb2720
A2 : 0x00000000 A3 : 0x3ffb2747 A4 : 0x00000003 A5 : 0x00000001
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x800e85be A9 : 0x3ffb2700
A10 : 0x0000472d A11 : 0x00000000 A12 : 0x0000472d A13 : 0x00006d80
A14 : 0x00003934 A15 : 0x00393430 SAR : 0x0000000a EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000000c LBEG : 0x40084765 LEND : 0x4008476d LCOUNT : 0x00000027
Backtrace:0x400e7fcc:0x3ffb27200x400e7f13:0x3ffb2740 0x400d36f3:0x3ffb2770 0x400ea895:0x3ffb2820
This is the code.
#include <Arduino.h>
#include <WiFi.h>
#include <Firebase_ESP_Client.h>
#include <Wire.h>
#include <Adafruit_AHTX0.h>
#include "time.h"
// Provide the token generation process info.
#include "addons/TokenHelper.h"
// Provide the RTDB payload printing info and other helper functions.
#include "addons/RTDBHelper.h"
// Insert your network credentials
#define WIFI_SSID "slt fibre"
#define WIFI_PASSWORD "Ssenath1234@"
// Insert Firebase project API Key
#define API_KEY "AIzaSyAl_-mSzachIEJshqgKXqtQY2_6ZhFSv90"
// Insert Authorized Email and Corresponding Password
#define USER_EMAIL "senathsethmika@gmail.com"
#define USER_PASSWORD "weatherkids"
// Insert RTDB URLefine the RTDB URL
#define DATABASE_URL "https://esp32-weather-app-default-rtdb.europe-west1.firebasedatabase.app"
// Define Firebase objects
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
// Variable to save USER UID
String uid;
// Database main path (to be updated in setup with the user UID)
String databasePath;
// Database child nodes
String tempPath = "/temperature";
String humPath = "/humidity";
String presPath = "/pressure";
String timePath = "/timestamp";
// Parent Node (to be updated in every loop)
String parentPath;
int timestamp;
FirebaseJson json;
const char* ntpServer = "pool.ntp.org";
// BME280 sensor
// I2C
float temperature;
float humidity;
float pressure;
// Timer variables (send new readings every three minutes)
unsigned long sendDataPrevMillis = 0;
unsigned long timerDelay = 180000;
// Initialize BME280
// Initialize WiFi
void initWiFi() {
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("Connecting to WiFi ..");
    Serial.print('.');
// Function that gets current epoch time
unsigned long getTime() {
  time_t now;
  struct tm timeinfo;
  if (!getLocalTime(&timeinfo)) {
    //Serial.println("Failed to obtain time");
    return (0);
  time(&now);
  return now;
Adafruit_AHTX0 aht;
  // Initialize BME280 sensor
  initWiFi();
  configTime(0, 0, ntpServer);
  // Assign the api key (required)
  config.api_key = API_KEY;
  // Assign the user sign in credentials
  auth.user.email = USER_EMAIL;
  auth.user.password = USER_PASSWORD;
  // Assign the RTDB URL (required)
  config.database_url = DATABASE_URL;
  Firebase.reconnectWiFi(true);
  fbdo.setResponseSize(4096);
  // Assign the callback function for the long running token generation task */
  config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
  // Assign the maximum retry of token generation
  config.max_token_generation_retry = 5;
  // Initialize the library with the Firebase authen and config
  Firebase.begin(&config, &auth);
  // Getting the user UID might take a few seconds
  Serial.println("Getting User UID");
  while ((auth.token.uid) == "") {
    Serial.print('.');
  // Print user UID
  uid = auth.token.uid.c_str();
  Serial.print("User UID: ");
  Serial.println(uid);
  // Update database path
  databasePath = "/UsersData/" + uid + "/readings";
  // Send new readings to database
  if (Firebase.ready() && (millis() - sendDataPrevMillis > timerDelay || sendDataPrevMillis == 0)) {
    sendDataPrevMillis = millis();
    //Get current timestamp
    timestamp = getTime();
    Serial.print ("time: ");
    Serial.println (timestamp);
    parentPath = databasePath + "/" + String(timestamp);
    sensors_event_t humidity, temp;
    aht.getEvent(&humidity, &temp);
    json.set(tempPath.c_str(), temp.temperature);
    json.set(humPath.c_str(), humidity.relative_humidity);
    json.set(presPath.c_str(), String(22 / 100.0F));
    json.set(timePath, String(timestamp));
    Serial.printf("Set json... %s\n", Firebase.RTDB.setJSON(&fbdo, parentPath.c_str(), &json) ? "ok" : fbdo.errorReason().c_str());
There is an exception decoder for ESP. I'm not sure if it supports the ESP32. You will have to use a legacy IDE (like 1.8.19) to be able to use the exception decoder.
The exception decoder will translate the messages that you get to something that can point you in the right direction.
Because you can compile and upload, this is not a question about troubleshooting the IDE :wink: Hence your topic has been moved.
