giving error on: From Arduino to a Microcontroller on a Breadboard
I'm trying with a new ATMEGA328 MCU to burn the boot loader by following this link
https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard.
This is the error.
"Arduino: 1.6.5 (Windows 7), Board: "Arduino Duemilanove or Diecimila, ATmega328"
Error while burning bootloader.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
enabled in File > Preferences.
Are those errors displayed while burning the bootloader, or while attempting to upload a sketch?
Please post the results with verbose output while uploading enabled.
That tutorial has a problem - it omits the decoupling capacitors, and those are necessary for reliable operation. Without them, it may or may not work, and almost certainly won't work once you start doing stuff. Use two 0.1uf ceramic capacitors - one goes between Vcc and Ground, the other between AVcc and Ground. These must be as close to the chip as possible.
These errors are coming while burning the bootloader. I'm little bit confused here how to proceed.
Well, first, install the decoupling caps like I described...
What programmer are you using to burn the bootloader?
If it's another Arduino, have you uploaded ArduinoAsISP sketch to it? You may also need to disable autoreset on the programmer arduino by putting a ~10 uf cap between Rst (of the programmer, not the target) and Ground.
