Hi
I am using KS0108 based GLCD 128x64 with U8g2 library.
I need to display a bmp image and some text. The text portion is working fine but the image is not being displayed. Here is the code:
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
////////////////////////////////// D0,D1, D2, D3, D4, D5, D6, D7, EN, RS, CS1, CS2 /////////////////////////////////////////////////
U8G2_KS0108_128X64_1 u8g2(U8G2_R0, 4, 5, 6, 7, 8, 9, 10, 11, 3, 2, A0, A1, /*cs2=*/ U8X8_PIN_NONE, /* reset=*/ U8X8_PIN_NONE); // Set R/W to low!
//////////////////////////////////// RST = 5V, R/W = GND //////////////////////
const uint8_t Size1_2Width = 64;
const uint8_t Size1_2Height = 64;
static const unsigned char Size1_2bmp[] U8X8_PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0xc0, 0xc0, 0xc0, 0xc0, 0xe0, 0xe0, 0xe0, 0xe0, 0xf0, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0xe0, 0xf0, 0xf0, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xc0, 0xe0, 0xf0, 0xf0, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x0f, 0x0f, 0x0f, 0x0f, 0x07, 0x07, 0x87, 0xe3, 0xfb, 0xff, 0xff, 0x3f, 0x0f, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0xf0, 0xfc, 0xff, 0xff, 0x7f, 0x0f, 0x03, 0x00, 0x00, 0x00, 0x00, 0xe0, 0xf8, 0xfe, 0xff, 0xff, 0x3f, 0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0xf0, 0xfe, 0xff, 0xff, 0x3f, 0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x1f, 0x1f, 0x1f, 0x0f, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x1f, 0x1f, 0x1f, 0x0f, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0xf8, 0xfe, 0xff, 0xff, 0x3f, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0xfc, 0xff, 0xff, 0xff, 0x3f, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x07, 0x07, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
u8g2.begin();
u8g2.firstPage();
do
u8g2.setFont(u8g2_font_helvR08_tf);
u8g2.drawStr( 15, 8, "SIZE");
u8g2.drawStr( 68, 8, "LENGTH");
u8g2.drawLine(0, 10, 127, 10);
u8g2.drawStr( 20, 22, "1/2\"");
u8g2.drawStr( 95, 22,"mm");
u8g2.drawStr( 20, 32, "5/8\"");
u8g2.drawStr( 95, 32,"mm");
u8g2.drawStr( 20, 42, "3/4\"");
u8g2.drawStr( 95, 42,"mm");
u8g2.drawStr( 20, 52, "7/8\"");
u8g2.drawStr( 95, 52,"mm");
u8g2.drawStr( 29, 62, "1\"");
u8g2.drawStr( 95, 62,"mm");
u8g2.setFontMode(1); /* activate transparent font mode */
u8g2.setDrawColor(1); /* color 1 for the box */
u8g2.drawBox(67, 12, 26, 12);
u8g2.setDrawColor(2); /* color 2 for the font */
u8g2.drawStr( 70, 22, "61.8");
u8g2.drawStr( 70, 32, "71.8");
u8g2.drawStr( 70, 42, "81.8");
u8g2.drawStr( 70, 52, "91.8");
u8g2.drawStr( 70, 62, "97.8");
} while ( u8g2.nextPage() );
delay(3000);
u8g2.clearDisplay();
u8g2.setBitmapMode(false /* solid */);
u8g2.drawBitmap(0, 0, Size1_2Width, Size1_2Height, Size1_2bmp);
delay(2000);
Kindly guide me to make the sketch work.
