GLCD issue
I recently hooked up my graphic LCD on my Arduino, but I can't get it to work.. Only the backlight shows up, and nothing else.
I don't know if it is a code issue, or hardware issue.
Can someone look below and see if I made a mistake in the hardware?
LCD: Graphic 128*64 LCD
LCD controller/driver: KS0107/KS0108
My current pinout between LCD and Arduino Diecimilla
GLCD - Arduino Diecimilla
 1   - Analog 0
 2   - Analog 1
 3   - GND
 4   - 5V
 5   - ? (Tried on 3.3V and 9V)
 6   - Analog 3
 7   - Analog 2
 8   - Analog 4
 9   - Digital 8
10   - Digital 9
11   - Digital 10
12   - Digital 11
13   - Digital 4
14   - Digital 5
15   - Digital 6
16   - Digital 7
17   - RESET
18   - GND
19   - 5V
20   - GND
Pinout of the Arduino PINs from the Arduino GLCD page:
Description on the Arduino GLCD page
5V       - 5+ volts
GND      - GND
external - Contrast in
8        - D0
9        - D1
10       - D2
11       - D3
4        - D4
5        - D5
6        - D6
7        - D7
A0       - CSEL1
A1       - CSEL2
RESET    - RESET
A2       - R_W
A3       - D_I
A4       - EN
external - Contrast out
external - Backlight +5
GND      - Backlight Gnd
Pinout from the manual of my LCD display:
LCD Manual PIN description
 1 - /CSA - Chip select for IC1, Active LOW
 2 - /CSB - Chip select for IC2, Active LOW
 3 - Vss  - Ground (0V)
 4 - Vdd  - +5V
 5 - Vo   - Power Supply For LCD Drive
 6 - D/I  - L > Instructions  H > Data
 7 - R/W  - H > Data Read (LCD > MPU)
            L > Data Write (LCD < MPU)
 8 - E    - Enable Signal
 9 - DB0
10 - DB1
11 - DB2
12 - DB3
13 - DB4
14 - DB5
15 - DB6
16 - DB7
17 - /RST - Reset, Active LOW
18 - Vee  - Negative Voltage output
19 - LEDA - LED Anode. Power Supply +
20 - LEDK - LED Cathode. Power Supply -
18 - GND
Pin 18 of the GLCD is the output of a power supply which is used to provide a negative voltage for the LCD drive at pin 5.
You have grounded the output of this power supply and then fed a positive voltage into the LCD drive pin.
You should connect pin 18 to the top end of a potentiometer (10K would work), ground the bottom end, and connect pin 5 to the wiper .
Don
Thank you very much for your reply. I will test it as soon as I get home.
I'll get back to you.
By the way, my LCD documentation says that Vo needs between 9 and 10 volts...
