GLCD PROJECT can t compile with arduino!!! (PGM12864A-NS(W)-BBW
I want to make gcld projects.And i download a lot of glcd libraries but i cant compile with arduino program.Give a lot of error.
I have glcd and its model code is PGM12864A-NS(W)-BBW.How can i find this glcd libraries and examples.Firstly i want to write "HELLO WORLD".And later other complex project.
Please help about it.Thanks a lot.
Do you have a link to a datasheet for the exact module you have?
The first thing to figure out is what chipset is on the module.
Once you know that there will be a limited number of libraries for that chip.
You will also need the datasheet for the pinout to know how to wire it up.
— bill
I can t find it,i write this code to google a lot of knowledge but which one.
i think that buy a new lcd.What do you think about i most buy which lcd ?
kaankoseoglu:
You buy an lcd from a supplier that:
  1. tells you it is for Arduino
  2. shows you which pins to connect to, or also supplies a compatible shield
  3. tells you which library to use
thereby leaving you in no doubt about what to do
Ebay
OK, THANK YOU.
Does anyone have a copy od the latest version of GLCD or OpenGLCD that will work on an Arduino UNO or NANO or even MEGA 3560
I have tried both versions and I get the same erro"compilinf error to UNO board or NANO boaed, which ever I try to use
Does anyone have any idea??
Jeff
stuartyh:
Jeff
Don't hijack this thread.
Start a new thread for your topic and include all the information needed to re-produce the error.
--- bill
Sorry Bill, I was not trying to hijack your thread. I was only looking for some information
