Glediator, Arduino, MAC
Hi all,
I am trying to use Glediator with a 20x20 LED Matrix, but with a Mac. I installed Glediator, downloaded the arduino sketches, and installed the RXTX Library using this link: Installing RXTX on Mac OS Mountain Lion | Brian Hemeryck
When I launch Glediator, the Arduino does appear in the Output mode window, but when I click on Serial open, it just doesn't connect. When i try to close the serial, it tells me it is already closed. I tried all the Baud rates, the glediator sketch is on the arduino, what am I doing wrong here?
I thought of maybe changing the Baud rate in the arduino sketch but I can't find any.
Any help will be greatly appreciated.
You are using glediator, which is an unfinished pile of crap.
Hey again,
Ok so what do you recommend i do then?
Hi, I'm trying to get glediator working and am having the same problem you described. Were you ever able to find a solution?
Thanks
Matt
I had the same problem, which I solved by an update of java and the download of the library RXTX (librxtxSerial.jnilib) here : RXTX for Mac OS X
have good day.
