Global char array or pointer for functions.
I am working on a program that reads a serial input message from a sensor console.
Then:
  • in a subroutine trailing spaces are removed.
  • another subroutine changes the message to one more understandable.
    all working on/with the same char array with each sub making its required changes.
This approach seems a bit crude (i.e. relying on a global to deal with "passing" to the subs).
My question is:
Should I be using pointers to "pass" the array to the subroutines? Or is it just as good simply using the global?
For me this is both a functional and learning experience so I tend to recreate some wheels by using my own subroutines.
Thanks
John
char Inputbuffer[40] = ""
// if there is data available from the sensor console, process it
   if (Serial.available() > 0)
    getConsoleMessage();    // Fills Inputbuffer with alarm message and then trims whitespaces
    }  //  .... if Serial.available
     trimEndSpaces();
     reFormatMessage();
//*** subroutines *************************************************************
void trimEndSpaces(){
int8_t i;
i=strlen(Inputbuffer)-2;    // the -2 to shift to 0 based and so we don't test the \0
while (Inputbuffer[i] = " ")
  i--;
  if(i=3) break;
Inputbuffer[i] = \0
  if(i=3) break;
I think you meant:
  if(i==3) break;
Also...
Missing semicolon...
Single equals is assignment. You want double equals for equality test. Also double quotes are strings, you want single quotes for comparing a char type...
Missing a semicolon. Also, what's the backslash all about? That needs to be inside single quotes if your trying for an escaped ASCIII NUL...
nputbuffer[i] = \0
Thanks for the pointers.
So should I assume using a global array to allow my subroutines to manipulate the contests is no worse or better than passing pointers?
JohnRob:
If the functions only ever work on one string, using a global is fine. If you have a function that you want to use on various strings, passing a pointer is better than having multiple functions that do the same operation on different global variables.
