Global objects
Hi all,
the sketch below prints "Serial started" and nothing else, it seems like setup or loop are never reached, and I can't see why... any idea?
Obviously this is a very simplified version of a real sketch where I am initializing lots of global objects...
Franck
class Dummy {
  public:
    Dummy() {
      Serial.println("Serial started.");
      Serial.flush();
Dummy dummy;
  Serial.println("In Setup"); Serial.flush();
  delay(2000);
  Serial.println("looping"); Serial.flush();
try getting rid of Serial.flush();
At the time the constructor is executed, not much of the Arduino environment is initialized. I guess your Serial.begin() is cleaned out.
arduino_new:
Well yes of course, but the real code was initializing a bunch of different objects so I added the Serial to debug that.
It turns out that an lcd.begin(...) in one of the constructors was the problem; I cleared all constructors and added a few begin() methods where needed and everything works.
I guess interacting with the hardware in global object constructors is not a good idea.
Thanks!
Franck
Even though there was no LCD code in the program you posted...
Which is why well written libraries have a init() or similar function that is called after the object has been created.
UKHeliBob:
Did you read the message?
"Obviously this is a very simplified version of a real sketch where I am initializing lots of global objects..."
Well written libraries? That's your point of view... it requires one more state for objects - constructed but not initialized - with its cohort of bugs and pitfalls.
It's more a characteristic of the platform that we have to accommodate, certainly not a feature.
Franck
Have you solved the problem with the sketch originally posted ?
I see, let me be more explicit...
The pb with my real sketch was an lcd.begin; I then added the Dummy debugging object to troubleshoot and the problem became Serial.xxx andlcd.begin. I removed both and the problem went away.
The pb with the sample sketch I posted was the Serial.begin().
Thanks for helping out - Franck
OK - understood
